Results 1 to 9 of 9
Thread: ph keeps rising
    ph keeps rising
    i like to keep my chlorine level at 6-7, i noticed the every time i add bleach to my pool my ph rises, is this normal? I then find myself battling with the ta, because when i add acid it lowers the ta as well.
    cya 50
    ta 80
    ch 300
    fc 5
    cc 0
    ph 7.2( added acid to lower it, was 7.7)
    24' x 52' Round AG 11,200 gal., 2 HP pump Cartridge Filter
    Re: ph keeps rising
    added the acid today, so now i know the ta is not 80 anymore, maybe 70 now!!!!! sorry did not test it after added the acid
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: ph keeps rising
    Typically adding bleach will raise ph a little but when it is used up the ph goes back down to about where it started...we consider it ph neutral. There have been a very few reports of "cheap" bleach with excessive lye that can raise ph a little...but as I understand it, very uncommon. Do you have any aeration in your pool?
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,591
    Re: ph keeps rising
    I'll let you know if anyone perfects how to lower Ph without lowering TA a wee bit as well.
    Re: ph keeps rising
    didn't know was aeration was. looked it up on google. no i don't, but i do have a fountain sprayer that i occasinally use.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: ph keeps rising
    Your fountain will raise the ph. Have you been using it recently?
    Re: ph keeps rising
    yes
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: ph keeps rising
    If you are going to keep using it, then I would let your TA go down a little more, but not below 60 ppm.
    Re: ph keeps rising
    okay thanks
