Results 1 to 11 of 11
Thread: Cleaning old Sand Filter
    Jun 2013
    Seguin TX
    192
    Greetings,
    Getting ready to use my old Hayward 16" sand filter.
    I have emptied the filter by opening the drain, removing the pump valve and sticking a hose into the sand and washing it.
    It has now been empty about two weeks with only the sand in it "no water" would this be good enough before hooking it up to the pump and pool?
    Should I then immediately backwash until the water runs clear?
    P.S. This filter sat idle about 5 years
    THanks
    2017-Intex Ultra Frame 16x48 5000 Gallons
    Intex 2800GPH Pump with 14" Intex Sand Filter
    My Intex Pool Setup Video :Intex pool rises from the ashes - installing and leveling - EP-72 - YouTube
    30,414
    Re: Cleaning old Sand Filter
    Is the "pump valve" a multi-port or a push-pull valve?
    Jun 2013
    Seguin TX
    192
    That would be a Multi-Port Hayward
    30,414
    Before you fill it up and reconnect everything, I would take the multiport apart and check the condition of the spider gasket inside.
    That's a long time to be dry and it might need replacing. Probably a bit easier job while it's apart from the filter.
    Jun 2013
    Seguin TX
    192
    The type of valve I have does not have a replaceable gasket, it is molded into the key/seal assembly.
    Like this http://www.poolzoom.com/key-seal-assemb ... 714ca.html
    30,414
    Yikes! Well, put it in and see how it works. 5 years....that assembly may need replacing but maybe not.
    Jun 2013
    Seguin TX
    192
    So..... My question again, should I just hook it all up when the pump comes in and see how it goes?
    Or do you think I rinsed the sand enough in preparation?
    I have a feeling the valve will be ok, it moves freely and doesnt bind, however whether it leaks between backwash-filter-rinse I know I wont be able to determine until the pump arrives and I hook everything up.
    Thanks
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Here is a link to the hayward manual that describes their recommenced startup on page 4:hayward manual I would do something similar to makes sure the sand is well rinsed before running water from it back to the pool.
    Jun 2013
    Seguin TX
    192
    Linen, thanks for the link I will follow their guide
    Jun 2013
    Seguin TX
    192
    Ok Folks,
    Got my new 3/4hp Dohenys Pump in on Tuesday, installed it and the old sand filter and base. This pump is nice a quiet and seems sealed really well from the elements. It also came with a cord
    Filter was backwashed for about 2 minutes and the site glass was clear, moved the handle on the valve to all positions and experienced no leaks and or bypassing to the other openings so I guess I am golden with the valve Even though it sat in the sun for 5-6 years
    Question is, I misplaced the screws that secure the pump to the sand filter base, does anyone know what size screws are used to secure the pump to the hayward Sand Filter base unit? I will post some pictures of the setup here in a few minutes.
    Thanks
    Jun 2013
    Seguin TX
    192
    Here is the location of the pump on the base, I do not know the model of the base unit, I do know it is a 16" hayward filter.
    I was able to also re-use the Intex hoses by slipping back the connector and placing a hose clamp around the resulting flange on the end of the hose, remarkably these are the two connection not leaking at this time, the other hose barbs need to be removed and re-done as I only did one wrap of teflon tape, the manual calls for two and they both have small leaks.
    So please help me with the screw size if you can
