Thread: Connect vacuum hose to strainer ???
    I have attached a picture of the strainer for my intex easy set pool. Is there some type of adapter/fitting that screws onto this strainer for my vacuum hose to attach to? You can see that it actually has 2 different sets of threads. If you can, provide a link to the product online so I can see what I need. Thanks.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,966
    Re: Connect vacuum hose to strainer ???
    I just tried the search function, and I think the first result has your answer. Search
    I have not been able to find online the part they speak of in the link in your post. I will have to call intex to find out what I need.
    The people at intex are idiots and don't speak english very well. From what I have gathered, I only see one hose adaptor for intex pools. It states it is for the small strainer, which I have the large strainer. If anybody reading this has the blue hose adaptor, would you be so kind as to measure the width of the female threads so I can see if the adaptor would fit my strainer? Also, is the "nipple" 1.5" outside diameter? Thanks.
