Page 1 of 2 12 LastLast
Results 1 to 20 of 31
Thread: Question about getting pool water tested at store
    partypond's Avatar
    Jul 2008
    Frisco, Texas
    89
    Due to my wonderful test kit and this great site, I have never had my water tested at a pool store. My question is do they check for CYA on normal testing? Is it very accurate? I would like to see if their results are near mine to make sure I am reading the test right. THX
    36x16 gunite, 14,500 gallons, Jandy 2.0hp VS Epump, Jandy CL460 filter, Automatic chlorinator, Jandy Legacy 400K BTU Heater, Polaris 1.5HP spa blower, 2 Colorlogic pools lights and 1 Colorlogic spa light, Polaris 3/4HP booster pump, Polaris 280 cleaner, Jandy PS4 with PDA, QuartzScapes Montego Bay plaster, OK flagstone coping, spray deck (aggregate effect) - completed 3/2011
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,067
    Re: Question about getting pool water tested at store
    Take it in and have a laugh. I'll wager large sums of money that what they read and what you read will be at huge variance. inconsistency-in-readings-t61728.html
    Jun 2012
    Howell, NJ
    977
    CYA is the test they are the worst at. Depending on the type of test they use, lighting is important. You need to test with the sun to your back, tube at waist level. The lighting is very different in the store. So no, don't trust a pool store o back up your tests. There are videos and pictures of how to do the tests floating around somewhere. Have you seen them?
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Pool store testing cannot be trusted. See Inconsistency in readings. It may appear free on the surface in that they do not directly charge for testing. However you get what you pay for. Plus, the real hidden agenda behind pool store testing is convincing you that you need the latest magic elixirs.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Don't drink the Koolaid!
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    But it's fun to mess with the pool stores!
    Take a 1 qt sample, do your own tests, then add a couple of drops of MA and bleach to the remainder. Maybe even throw in some tri-sodium phosphate. Take the altered sample to your least favorite PS, then have a good laugh at what they try to sell you.
    partypond's Avatar
    Jul 2008
    Frisco, Texas
    89
    Charlie - now that is funny!!
    I will just stick to my tests. I think I am good but I thought it would be interesting to double check. THX
    Donldson's Avatar
    NW Ohio
    2,917
    Quote Originally Posted by Charlie_R
    ... I am really tempted to do this if I know a pool store will check for phosphates. I would love to see the look on their face and then realize how much phosphate remover they think they will be able to sell. And then I get to say "eh, I suppose I will just throw some bleach in"
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Jeetyet's Avatar
    Jul 2012
    Florida Panhandle
    200
    It might be a good idea to "make the rounds" of any local pool stores with some pre-tested water every now and then just to get a feel for which one/s might be closest to returning correct results. Then, in the future, if for whatever reason you have the need, you'll know which (if any) you can make use of if you have to for ballpark estimates.
    "The early bird might get the worm, but its the second mouse that gets the cheese." ~ W. Rian Adams
    Relative's IG Vinyl | 16x32 | ~18,600 gals | Hayward 3/4hp Pump | Hayward S244T Filter | Pentair Model 300 Chlorinator (not used) | Polaris 180
    22,553
    I wouldn't recommmend purposefully "messing" with the pool store. They are helpful for some things and it's not our way to deceive people even if it is the pool store. Besides they mess the tests up bad enough without trying to be deceitful.
    Smykowski's Avatar
    Sep 2011
    3,065
    They are helpful for some things .....
    There's a pool store not too far away from me that I used before finding TFP. I won't let them near my water, but they've been a huge help with parts, some of which I didn't even know how to describe.
    Mar 2011
    Houston, Texas
    413
    This. And for what it's worth, the test results of the two stores near me are substantially consistent with my results.
    The real problem, however, is that they don't follow the suggested chemistry levels found here. They always tell me to add baking soda to get my TA up--even when it's around 80 or 90 and could go LOWER. They even say that raising TA to their recommended levels will help "lock in" my pH and prevent pH from rising. The opposite is true.
    They don't acknowledge the CYA/Chlorine relationship we follow. They simply say to keep your chlorine between 1-3 ppm. And they always freak out about my phosphates. One time the person looked terrified after the phosphate test and asked me how my water looked. I just smiled and said it was perfect. He was shocked and skeptical. He still tried to sell me some phosphate remover.
    9,200 gal. Gunite Luna Quartz French Grey pool with spill over spa, two fountains on tanning ledge (rarely used)
    Pentair Whisperflo 2HP, Pentair CCP Cartridge 420 Sq. Ft., Polaris 280 with booster pump
    Pentair EasyTouch 4, RayPak LoNox 266k Natural Gas heater, Aqua Rite SWCG T Cell 9, Borates, TF-100 test kit
    Donldson's Avatar
    NW Ohio
    2,917
    I'm not that mean, I won't go out of my way to mess with them. Best revenge is to convert as many people as possible. The TSP water is just a funny thought, not an actual plan
    30,432
    TFP recognizes the temptation to "get even" with the pool stores but we would don't want to encourage others to do it. (We're just no fun, are we. )
    Many, many pool store people do what they do out of ignorance rather than any malice. Their education comes solely from the chemical suppliers.
    TFP suggests we just leave them alone.
    Besides, everyone should spend their free time re-reading Pool School because you just never know when a pop quiz could appear on this forum and you need to be ready.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Yes, Dave, I do agree that messing with most pool stores may not be a good idea. I put that out there in jest. I really wouldn't want someone to actually do it, but just the thought of it is funny.
    So bring on the pop quiz!
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    POP QUIZ!!!!!
    COKE or PEPSI
    -- Guy --
    Jun 2012
    Howell, NJ
    977
    That's an easy one. Mexican Coke. Now give me a harder one.
    John
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Margarita "on-the-rocks" or in the blender?
    -- Guy --
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Aww, now you are making me want to go to Mexico, and my wife and I just booked an Alaskan cruise for next month
  20. Back To Top    #20
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    OK... then "Coronitas on the beach" or "crab aboard the cruise ship"?
    -- Guy --
