Thread: water behind liner
    Mar 2012
    Lebanon,Tn
    47
    water behind liner
    I live in TN, we had about 10in of rain today, came home to full and overflowing pool. when i was pumping the water down i saw the side wall was puffed out i felt it and there is water behind the linner. what can i do if any, Help.
    21x42 olympic sports pool
    18000 gal
    Intelliflo vs pump
    Pentair ic40 SWG
    Suntouch control
    TR100 Pentair sand filter
    Letro ledgen II pool cleaner
    Vinyl liner
    TF Test Kit's TF100
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: water behind liner
    I am assuming in ground vinyl. If it is, did the PB put in a "dry well" or sump tube near one side or end?
