Normal FC loss during day
TCJ4
Jan 19, 2013
229
Aruba
Yesterday after noon i added 8oz of cal-hypo to raise my FC to 7 but just now i tested the FC and it's 1.5.
Is is to normal to lose that much FC during the day?
Pool gets alloooot of direct sunlight,from 7am to like 6pm
CYA :40
It does seem a bit excessive, but if the sun is on it all day it could happen. Best way to find out if you have a problem is to perform an OCLT. If you lose more than 1 ppm overnight then you do have something that needs SLAMed in to submission.
The normal FC loss per day is somewhere between 2-3 ppm per day (24 hours) around this time of year. So your loss seems quite high at first glance. Was is over 24 hours since the prior chlorine dose?
To confirm if there is any organic contamination in the pool, you could run an OCLT.
Going forward, I would recommend dosing with chlorine in the early evening (after sunlight is no longer hitting the pool).
TCJ4 said:
Should i slam it tomorrow morning or in the evening?
Either is fine, as long as you wait 1 hour with the pump running after your last dose before you do the evening OCLT measurement.
TCJ4 said:
Ps:im gonna slam it with cal hypo because i have allot of it and my CH is at 50
That is fine, but you may want to keep a log of what you are using...it can add up fast.
Just checked the part from pool school that said that if u have allot of direct sunlight u should keep the the CYA level higher,just wondering if that's the problem.
My current CYA is at 40.
Tomorrow gonna check everything again just to be sure.
Do the OCLT first and see if you have organics...if you do then continue the SLAM process until that is done. If not, or when you finish the process, I would carefully bump up to 50 ppm cya (and maybe even a little higher for your climate).
With 40 ppm you might normally see around 50-60% loss over 24 hours so from 7 to 2.8 or 3.5 ppm so getting to 1.5 which is a 79% loss seems excessive. The OCLT will tell you more; most likely you need to SLAM the pool to kill off nascent not-yet-visible algae growth. With your hot sunny area, a CYA of 50 ppm or more would make more sense. At 50 ppm you may lose about 40% over 24 hours and at 60 ppm a little less loss while at 80 ppm it may be around 22%, but such a high CYA becomes risky if you ever need to shock since it takes a lot more chlorine to get to the required shock FC level.
Just checked the water FC:1ppm
CC:0ppm
So i think i passed the OCLT,the water is still clear.
Do u guys recommend continue using 3" thrichlor because i stopped using them when my CYA was at 40.
I'm now using 65%Cal-Hypo.
Will post a full test result later
I wouldn't consider that a good OCLT. You should raise the FC to shock level and then run the test. 1 ppm FC is way too low for your pool anyway. You should have added FC as soon as you saw it was that low. Leaving it that low for any length of time is asking for trouble.
