Page 1 of 5 1234 ... LastLast
Results 1 to 20 of 87
Thread: Normal FC loss during day
    Jan 2013
    Aruba
    229
    Yesterday after noon i added 8oz of cal-hypo to raise my FC to 7 but just now i tested the FC and it's 1.5.
    Is is to normal to lose that much FC during the day?
    Pool gets alloooot of direct sunlight,from 7am to like 6pm
    CYA :40
    Intex 15X48" /5300 galloms
    Intex 2650 sand filter
    Thru wall skimmer,
    FAS-DPD chlorine test kit K-2006
    Hard plumbed
    Donldson's Avatar
    NW Ohio
    2,895
    Re: Normal FC loss during day
    It does seem a bit excessive, but if the sun is on it all day it could happen. Best way to find out if you have a problem is to perform an OCLT. If you lose more than 1 ppm overnight then you do have something that needs SLAMed in to submission.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    The normal FC loss per day is somewhere between 2-3 ppm per day (24 hours) around this time of year. So your loss seems quite high at first glance. Was is over 24 hours since the prior chlorine dose?
    To confirm if there is any organic contamination in the pool, you could run an OCLT.
    Going forward, I would recommend dosing with chlorine in the early evening (after sunlight is no longer hitting the pool).
    Jan 2013
    Aruba
    229
    I chlorinate in the evening and i had checked FC yesterday and today in the early evening.
    Thru wall skimmer,
    Hard plumbed
    Jan 2013
    Aruba
    229
    Just checked it again it's still 1.5 and CC is 0
    Thru wall skimmer,
    Hard plumbed
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    That seems like to much loss. I would follow the advice above, raise your FC to your SLAM level and do a OCLT.
    Jan 2013
    Aruba
    229
    Should i slam it tomorrow morning or in the evening?
    Ps:im gonna slam it with cal hypo because i have allot of it and my CH is at 50
    Thru wall skimmer,
    Hard plumbed
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by TCJ4
    Either is fine, as long as you wait 1 hour with the pump running after your last dose before you do the evening OCLT measurement.
    That is fine, but you may want to keep a log of what you are using...it can add up fast.
    Jan 2013
    Aruba
    229
    Just checked the part from pool school that said that if u have allot of direct sunlight u should keep the the CYA level higher,just wondering if that's the problem.
    My current CYA is at 40.
    Tomorrow gonna check everything again just to be sure.
    Thru wall skimmer,
    Hard plumbed
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Do the OCLT first and see if you have organics...if you do then continue the SLAM process until that is done. If not, or when you finish the process, I would carefully bump up to 50 ppm cya (and maybe even a little higher for your climate).
    Jan 2013
    Aruba
    229
    I'm gonna go and check the FC level now.
    I didn't add any chlorine since checking in the afternoon
    Thru wall skimmer,
    Hard plumbed
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    If you have the time you could do the OCLT tonight. Just make sure you give whatever chlorine you add an hour to mix before doing the evening test.
    Jan 2013
    Aruba
    229
    Just checked it the FC is 1ppm(dropped 0.5)
    So in 7 hours it dropped 0.5ppm
    CC:0
    Thru wall skimmer,
    Hard plumbed
    Jan 2013
    Aruba
    229
    Did not add any chlorine
    Thru wall skimmer,
    Hard plumbed
    May 2013
    Bay City, Michigan
    283
    1ppm is not good, you need to add chlorine! Should never let it get below 3 per CYA chart. OCLT test or not you can't leave it at 1ppm
    12500 gallons, 24 foot round above ground
    Hayward Sand filter, Pentair OptiFlo 1HP 2-Speed pump
    Jan 2013
    Aruba
    229
    I will be adding chlorine tomorrow morning
    Thru wall skimmer,
    Hard plumbed
    Mar 2007
    San Rafael, CA USA
    12,082
    With 40 ppm you might normally see around 50-60% loss over 24 hours so from 7 to 2.8 or 3.5 ppm so getting to 1.5 which is a 79% loss seems excessive. The OCLT will tell you more; most likely you need to SLAM the pool to kill off nascent not-yet-visible algae growth. With your hot sunny area, a CYA of 50 ppm or more would make more sense. At 50 ppm you may lose about 40% over 24 hours and at 60 ppm a little less loss while at 80 ppm it may be around 22%, but such a high CYA becomes risky if you ever need to shock since it takes a lot more chlorine to get to the required shock FC level.
    Jan 2013
    Aruba
    229
    Just checked the water FC:1ppm
    CC:0ppm
    So i think i passed the OCLT,the water is still clear.
    Do u guys recommend continue using 3" thrichlor because i stopped using them when my CYA was at 40.
    I'm now using 65%Cal-Hypo.
    Will post a full test result later
    Thru wall skimmer,
    Hard plumbed
    22,549
    I wouldn't consider that a good OCLT. You should raise the FC to shock level and then run the test. 1 ppm FC is way too low for your pool anyway. You should have added FC as soon as you saw it was that low. Leaving it that low for any length of time is asking for trouble.
  20. Back To Top    #20
    Jan 2013
    Aruba
    229
    I will add some cal hypo now just to raise the FC to 5 and in the evening raising it to shock level and doing the OCLT again.
    Thru wall skimmer,
    Hard plumbed
