Results 1 to 7 of 7
Thread: 1st set of numbers
    May 2013
    Tulsa, OK
    83
    1st set of numbers
    Pool is up and pump and filter are running.
    It set for a day while i was stuck at work. But now im on top of it i hope
    CYA 30 assumed just added about 2 lbs.
    TA 70
    PH 7.3 (looked in between .2-.5)
    FC 0 adding 105oz of 8.25% to bring me to a target 8
    CH about to test it once it quits pouring.
    Hope im on right track. I have been reading PS a bunch.
    will test FC again in about 30 to let it mix.
    12x24 Doughboy. 8700 gallons~ 2 HP Dyanmo Pump~ 26" Sand Dollar Filter~TF 100 test kit~ Zodiac Ranger AGP automatic cleaner.
    38,521
    Re: 1st set of numbers
    Don't raise you FC that much until the CYA is mostly dissolved. With 0ppm of CYA, a FC of 2ppm is plenty. Then once dissolved with a target of 30ppm, keep the FC > 2ppm and around 3-4ppm ... unless you think there is some reason to SLAM it.
    May 2013
    Tulsa, OK
    83
    It just worries me setting there for about 25 hours with nothing in it but water. There's some dead bugs few leaves. It's got another day before I'll let anyone use it. I just wanted to ensure I or off o a good start.
    This pump is a monster the cya is about gone already.
    May 2013
    Tulsa, OK
    83
    Speed Stir Question....
    Do I need to add my drops of reagent then stir, or can I start it stirring and add while its stirring. I didn't see any specific instructions about not doing that, but I don't want to get bad numbers by doing that.
    22,553
    I start the stirrer and then begin adding drops for all the reagents.
    May 2013
    Tulsa, OK
    83
    Sweet, I figured it would be ok...
    Thanks
    wjr75's Avatar
    Jun 2013
    IL
    836
    Concerning using the speed stir. I've never seen anyone post this before but get your water level first in the graduated cylinder and then put the speed stir magnet in which will displace some water making it look higher.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
