Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: How Often Do You Add Water?
    I normally have to have 1" - 2" of water to the pool every 5 - 7 days. I thought I had a leak, but everything I checked seems to be o.k. And I've been told there's a lot more to evaporation - and a lot more to evaporation at night! - than you would think. I've done the "bucket test" and it seems fine.
    These last two weeks have been very hot and very humid in central Florida - I've had to add 1" - 1.5" of water every two to three days.
    How often do you add water? Once a week? Every day?
    And how much when you do have to add it?
    I'm especially interested in hearing from the closest-to-central-Florida folks, but all input is welcome!
    If I keep adding so much, I might have to go back to playing leak detective. Not looking forward to that.
    15,000 gal, IG, Vinyl
    Cartridge Filter: Hayward C12002, 120 GPM
    Pump: 1.5 hp, Flotec AT251501-01
    TF-100 Test Kit
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,552
    Re: How Often Do You Add Water?
    You sound in the normal range to me for this time of year, cause there's nothing normal about 106 degrees to me here today! The wind along with the heat doesn't help any either. You can reduce your loss with a cover------but I'm too lazy for all that!
    May 2012
    Northern Connecticut
    103
    I have to dump water every few days...all it does is rain!
    24,000 20x42 double roman end in ground pool being built. Start date june13, 2012.
    Finished July 4th, 2012, sports pool, vinyl,SWG, DE filter, fountains. Heat pump,
    First Pool Ever!
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Within the last couple of weeks, I have topped off weekly. Throughout much of July, it was about every other week (was cooler & wetter than normal). Definitely correlates with air temp, wind, and precipitation.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    I add water every week or so when the skimmer makes gurgly noises. It usually needs/gets an inch or two but I have been known to forget about the hose. I added my hose timer back this week..
    -- Guy --
    Jun 2007
    New Jersey
    653
    I haven't uncoiled the hose all summer since I pressure-washed at the open. Too much rain.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,047
    We have had a lot of rain the last couple of months in Jacksonville so I have not had to add water, however lately we have not had any rain and last week I had to add water. I also will have to add water today or tomorrow for a party.
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    Aug 2010
    Lake Jackson, TX
    130
    I add about an inch a week this time of year. I'm on the same latitude as you, similar weather.
    25000 gal IG gunite plaster. Built in spa, built 1984.
    48 SF Hayward DE-4800 filter
    1 hp Hayward super pump
    3/4 hp Polaris PB-4 booster pump, Polaris 380
    Taylor K-2006 test kit
    Thanks for the replies.
    I started a new bucket test last night...so far this isn't looking promising. It's been about 18 hrs, and the bucket is down about 1/8"-1/4", the pool is down about 1.25". Not sure about the measurements, but the visual difference is more than obvious.
    The pump seems to be holding water, so I don't think there's an air/water leak between the skimmer and the pump - is that a fair assumption? (Of course, there could be a leak around the skimmer gasket, right?)
    So, now I need to check various gaskets and connections with dye/food coloring - right?
    How do I test from the pump to the returns?
    Nic
    TF-100 Test Kit
    22,537
    The first thing I would do, if you don't have a main drain is seal off the skimmer and returns and run the bucket test again. That will tell you if it's plumbing or shell. If you have a main drain that runs all the way to the pad, do the same and it just leaves the main drain and the shell.
    Thanks Bama Rambler,
    I do have a main drain; I believe it runs to the skimmer. In the bottom of the skimmer, I have two 1 1/2" holes - one I put my pool vac in, the other has a cover. It never receives suction. Is that the main drain?
    Would this main drain have 2 pipes? One to the skimmer/one to the pump? Or just the one to the skimmer?
    How do you seal off the skimmer, returns and main drain under water?
    Nic
    TF-100 Test Kit
    22,537
    Post a pic of the two holes in the bottom of the skimmer if you can. That's most likely the main drain hole. I wouldn't worry about plugging the main drain in the pool until you find out what the first test shows.
    Use winterizing plugs to seal off the skimmer pipe and returns. You could also stick the vacuum hose in the skimmer and leave the other end over the top.
    Here's the bottom of the skimmer. I tried looking for a make/model # but could only find them for the cover.
    I can think of some rubber expanding plugs at the auto parts store. Around here, it doesn't get to freeze very often. We will get down to 28 some times, but as soon as the sun comes up, it shoots to mid 30s. Rarely will it stay in the 30s for a day.
    TF-100 Test Kit
    22,537
    Have you tried opening that cover over the second hole?
    It most likely goes to the MD. You need a diverter to make it work correctly if it does.
    Yes, I have opened it...just a hole. With water in it. While the pump is running, there is no suction down at the main drain.
    I guess we'll head to the hardware or auto parts store for those plugs today. Start a new bucket test and go from there...yes?
    Thanks Bama!
    Nic
    TF-100 Test Kit
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Is that a crack near the second cover?
    -- Guy --
    You had me freakin' out there, for a second Techguy.
    No, that's a piece of grass.
    TF-100 Test Kit
    Sit Rep:
    I have the two returns plugged and the skimmer-to-the-pump plugged.
    I do NOT have the 2nd hole in the skimmer plugged (the one to the main drain). Do I need it plugged?
    I moved the tape on the skimmer down to the new level. We shall see.
    Oh, and most importantly, I have the pump set to off!
    Thanks for all your help.
    TF-100 Test Kit
    I'm guessing I got a problem.
    After almost 48 hours, the bucket is down 1/2".
    The first 24 hours, the pool dropped 1-1.5".
    I plugged the 2 returns and intake in the skimmer.
    24 hours later, the pool is down another 1-1.5".
    TF-100 Test Kit
  20. Back To Top    #20
    22,537
    That eliminates part of the plumbing. So you have left the shell and the main drain.
    You cna let it leak and see where it stops. Or you can try to seal off the main drain and see if that's it. I'd probably let it leak down to the level of the light to see if that's it if it were me.
