Results 1 to 7 of 7
Thread: Calcium Level
    Calcium Level
    Split from 2007 thread. Bama
    32,000 plaster pool in Hawaii 80-90-temp, light to moderate use condominium pool, 5.0 bleach level. 7.6 PH, CYA 80, Calcium level is 180 . What should it be I have heard 300 is good.. thanks Woody
    22,553
    Re: Calcium Level
    How old is the plaster?
    For a plaster pool 250 to 350 is a good place for the CH to be.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,052
    Re: Calcium Level
    Welcome!
    With a plaster pool, you want more CH, as Bama said.
    You could raise it with Cal-hypo, since you need to raise FC a little, too.
    38,475
    Re: Calcium Level
    Welcome to TFP!!!
    I am inclined to also point out that a FC level of 5ppm is too low for a CYA level of 80ppm:
    pool-school/chlorine_cya_chart_shock
    Re: Calcium Level
    Chlorine level is 5ppm not.5 is that still not high enough?
    38,475
    Re: Calcium Level
    Nope. Look at the link I provided.
    Re: Calcium Level
    OK 6-11 thanks Woody
