Thread: Looking for reliable, performing AGP cleaning robot
    Apr 2013
    Atlanta, Georgia
    11
    Can anyone recommend a reliable automatic pool cleaner robot that will work well in a dish bottomed ABG pool that's 16'x32' and 4.5' deep and doesn't break the bank? We really liked the performance of the Aquabot S2-40 when it worked, but clearly there is a quality issue with this model as I've described below. Any suggestions by persons with 1st-hand experience would be greatly appreciated!
    BACKGROUND: We purchased a brand new Aquabot Pool Rover S2-40 off Amazon for ~$300 a few months back. From a performance standpoint it worked absolutely great for about 4-5 weeks, with a few exceptions where the cord either got tangled or it got caught up on the steps in my Intex Ultra Frame 16'x32' rectangle pool w/ SWG. Overall though, it kept the pool squeaky clean when it worked. However, about 2 weeks ago it failed; it would run for a few seconds and then stop in the middle of the pool and the transceiver's blue led lights would synchronously flash. I got it RMA'd through the online seller and within a few days had a brand new replacement unit. Immediately, the replacement unit failed with the exact same behavior as the first. I wrote the seller and asked for a full refund which we're in the process of obtaining.
    So, where do we go from here? I want my pool to stay as clean as possible but I don't want to spend more than is necessary to do so.
    Suggestions? I appreciate everyone's thoughtful insight.
    14,364gal AGP
    Intex Ultra Frame 16'x32'x52"
    Krystal Clear™ Sand Filter Pump & Saltwater System - 2,650 GPH
    Aquabot Pool Rover S2-40 Pool Cleaner
    2 dedicated 20-amp GFIC's for pum, filter and cleaner
    Installed on concrete patio w/ 1-1/2" extruded polystyrene base
    10'x36'x54" pressure treated deck w/ 6"x6" posts, 2"x10" joists & beams, 42" rails
    Makdaddy's Avatar
    Jul 2012
    Springfield Illinois
    119
    Re: Looking for reliable, performing AGP cleaning robot
    I Just got a Wanda the Whale by Hayward
    Its not a robot.
    But it cleans my 24 AGP in 3 hours and will not get stuck on my Wedding cake
    It work way better then I ever thought it would
    --- Greg----
    24 x 54 Round Cozumel AGP with Grand Entrance Step 14500 Gal
    Running ntex Krystal Clear Saltwater System with E.C.O.
    A/G Cristal Flo II Sand Filter Tank w/ 2HP, 2-Speed Dynamo pump -Zeobest
    TFT Test Kit---Gorilla Floor and Foam Pool Cove--Half Deck
    Apr 2013
    Atlanta, Georgia
    11
    Thanks, Makdaddy. I'm not sure how that product would work with our Intex Ultra Frame pool, though.
    The Ultra Frame pool does not have a traditional skimmer basket in or on the side of the pool. It has a plastic drain cover that attaches to the pool wall that allows water to flow out of the pool, through it to the outside the pool and into the skimmer basket that is actually attached or, a part of the pump itself. From there the water flows into an inline SWG (again, part of the pump), into the sand filter and back into the pool. This is kind of why I've been looking for a robot, unless of course someone can show me how this unit would work on an Intex Ultra frame?
    Again, many thanks for everyone's comments and suggestions.
    14,364gal AGP
