Results 1 to 14 of 14
Thread: Brand New Pool Fails the Bucket Test?
    I have a brand new pool still under construction. I filled it just last Sat for the first time ever. It was awesome watching it come to life. At 3a it was full.
    But then I got up and went to show my wife at 8a and it was just below the tile line (2 inches lower than "full" over night).
    Days later, I still find myself adding 2 1/2 - 3 inches worth of water each day. I read last night to try the bucket test. This morning the bucket reduction was under 1/4" for 12 hours (overnight) and the pool had lost about 1 1/8" of water.
    I asked my pool company - at first I got a standard reply that "all pools loose water to evaporation" but upon giving them the results of the bucket test they said they'll "take a look". I'm witholding the final payment for now.
    Anyone able to comfort me into thinking this is something they can resolve? Quickly? Easily?
    ________
    FYI - pool is 14,000 gallons. Roughly 385 sq ft surface. Temp = 105* at 7p. Temp = 81* at 7a. Depth is 3.5 x 4 x 5. Live in Fort Worth.
    New Pool: 22’ x 35’ | StoneScape Mini - Midnight Blue | ~17,500 gallons | Jandy Equipment - Built spring 2015 (click for details and pictures)
    Old Pool: 16’ x 30’ | QuartzBrite | 14,000 gallons | Pentair Equipment - Built summer of 2013 (click for details and pictures)
    May 2013
    North East Ohio
    959
    Re: Brand New Pool Fails the Bucket Test?
    Think we need more details...in ground we assume ?
    How is it constructed ? Did you check the pumps, etc...that is a common place. Or are their not pump yet, etc.
    Did they do a pressure test before they backfilled, etc. ?
    More details please...
    It can be resolved quickly though...or maybe not.
    14,750 GAL IG Fiberglass (16 x 33) NE Ohio || Jandy 1HP 2 speed Pump || Waterco MultiCyclone 16 Centrifugal pre-filter (removed due to not working with sand filter) || 30" 575 Lb. Sand Filter || AquaCal 140K BTU Heat Pump || Solar Cover || Inter-fab Adrenaline Slide || GLI Monsoon Solar Cover Reel || K-2006C Test Kit || BBB with Liquid Chlorine Stenner Injection || Rayner Mighty Mesh Winter Cover
    22,550
    As mentioned above we need to know more. However, whatever it is won't be a concern for you. At this point it's the PB's problem. So whatever it is will be fixed. Hopefully it's a simple plumbing problem.
    Well, you at least helped prevent me from freaking out.
    Yes, its an in-ground gunnite pool. None of the pumps have been turned on yet. They were going to enable them today for the first time but decided to wait another day so they could do the bucket test themselves. I had been adding water every day because I didn't want the water to fall below the tile. Apparently that wasn't good for the acid bath its in and they want another day just to be sure of everything.
    He did tell me it could be something as simple as a skimmer or light not being fully sealed. They didn't make a big deal of it but said they were going to do a pressure test tomorrow on the plumbing and then a die-test if the pressure test doesn't give helpful results.
    They submitted my final bill to me. I presume I should hold payment until the pool actually works, right? Seems like a no-brainer.
    22,550
    Since it's gunite, it's probably not the shell leaking. So it's probably going to be something minor.
    I would hold payment until it's proven leak free and all the equipment has been thouroughly tested. In fact, I'd give it a day after the repair and run another bucket test and then cut the check.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,396
    You should hold the final payment until you are satisfied with the pool. Do you best to keep things friendly and polite, even if they get a little testy with you, and document everything that is said and done about the pool if you haven't already. Take lots of pictures as well. Even if you don't need this information to argue your point with the builder, it can be handy to have in the future.
    As Bama said, it is probably not a difficult repair. Has the decking been poured yet?
    Love TFP? Become a
    TFP Supporter!
    May 2013
    North East Ohio
    959
    Hold the payment, but let them know as nice as possible...surely they will understand.
    Thanks for the great advice. Yup, deck was poured. They made it sound like it was probably something small. I did see a bubble come from a pipe earlier today. I'd bet the pressure test will find something. I feel more confident but I will let them know I'm going to hold the payment until we've reached the milestone. I really appreciate ya'll helping me. Sounds like 1-2 inches of loss per week is normal from evaporation. I was done 1/4 inch this morning in 90 minutes... so the important part is that they acknowledge a problem.
    RIRSZ's Avatar
    Jul 2012
    Central New Jersey
    54
    I would think that you shouldn't have to pay until your pool passes final inspection.
    George
    32k gal IG free form / Vinyl Liner (cement wall) / Jandy 2 HP FloPro
    LRZ400EN Heater / Jandy CV460 Cart. Filter
    Paramount Vantage in-floor pool cleaner / built April 2013
    Pool Equipment Picture (on Flickr)
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    We didn't pay the final payment until after "pool school". Pool school occurred about 1 week after pool was actually up and running. During that week they had to replace the pool automation main computer board. That was when the pool builder justified why he waits a little while before considering everything "done". He had us run the pump 24/7 for that week. I don't know if the board was actually broken or not, but the fix was to "swap it with a new one".
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    There are many possible places, such as:
    1) Plumbing
    2) Light conduit
    3) Hydrostat
    4) Plaster or grout seal around fittings, skimmers etc.
    If the plumbing checks out, then you might need a diver.
    Do you have floor returns, or wall returns, or both?
    Do you have an in-floor cleaning system?
    Support the site
    ...amazing, this is what they suggested in that same order. Plumbers are coming out today. They'll send a diver down on Monday to check lights and returns if plumbing isn't successful. You guys really are quite helpful. Thank you very much.
    If you hit groundwater on the dig, then I would suspect the hydrostat. Groundwater can open the hydrostat. It will usually reseal, but sometimes sand or other debris will prevent it from resealing.
    Support the site
    I haven't picked up this computer since I posted this and wanted to post an update. The pool company sent a diver out to do a dye test and found a leak in the LED lights. Quick and easy fix.
