Thread: New SWG- FC still high. Cut down on run time or %?
    May 2013
    Fort Lauderdale, FL
    423
    My new pool pilot nano+ is running great. Before I left for vacation, I SLAMmed the pool and left 3 pucks in a floater. When I got back, FC was around 14. I got all the numbers in check and added the nano+. Right now it's running 8 hours a day and has been on for nearly two weeks. The FC had not been coming down, so I went from 50% to 35% on the nano. Now after a few more days I'm still seeing FC of 9.5. Pool looks awesome. I'm thinking about cutting the run time back to 6 hours a day before I drop the % anymore and see what happens. Any thoughts?
    Last full test was on 7/28 and I had:
    FC 11.5
    CC 0
    TA 90
    Cal 300
    CYA 45
    Salt 3000
    45'x12' 17k gal, IG plaster, Pool Pilot Nano+ SWG, 1/2hp Whisperflo pump, PAC-FAB TA-60D sand filter, Raypak 266 heater
    Pool School + Test Kit + Pool Math = Trouble Free Pool
    Butterfly's Avatar
    South Carolina
    10,045
    Re: New SWG- FC still high. Cut down on run time or %?
    I suggest that you raise CYA to about 70 and turn off the SWG until the FC drops to about 5 or 6ish.
    You're done SLAMing when:
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    How much full/direct sunlight is your water getting?
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    30,415
    +1 what Butterfly said.
    May 2013
    Fort Lauderdale, FL
    423
    It gets partial sun through the day. Look at my avatar pic- the pool is heavily shaded in the morning and late afternoon due to lots of tall trees around. I forgot, I did put a sock of CYA in since that test and it's up around 70 right now. I'll turn off the pilot and let it settle down. Thanks for the suggestions.
