Thread: Installing a new liner.
    Marillion Fan's Avatar
    About a 1/2 hour from P.S.U.
    259
    After 4 years of playing with the pool store chemicals and not having clear water all season long, I finally found Pool Forum and eventually sliding over here, and have had crystal clear water for the past 2 seasons.
    After reading a number of posts from both sites I have found that my bad pool care is most likely the cause for the myriad of wrinkles I now have in my liner.
    I believe there was some discussion of improper water balancing can cause the vinyl liner to expand and shrink causing said wrinkles, that and having some holes that have been patched have me looking into replacing my liner, probably before next years swim season.
    So I'm putting the question out there for the installers and DIY'ers.
    I plan on doing it myself (with help of course) and was wondering what is the best/easiest way of installing a new liner?
    We have an 18x33x48" oval with an overlap liner, the base is concrete dust with happy feet on top.
    I know I will have to relevel the floor as a couple of the leaks were on the floor and we now have dips that the water washed away the base.
    Is it best to put the liner in and vacuum it against the walls or let the weight of the fill water do that for us?
    Again this isn't going to happen till next year, I just wanted to get all the info I could before going head first into something that I don't have the slightest idea of how to do.
    18x33 15700 Gal Oval Above Ground
    Ranger Sand Filter w/Praher Multi Port Valve
    A.O. Smith 1.5 hp Pump
    Confer E9120 Steps
    BBB And Sparkling Clean.
    Re: Installing a new liner.
    We paid to have ours replaced. I have to say though, after watching them do it I think I could have done it myself.
    Here are a couple of helpful links:
    http://www.ehow.com/how_2071125_replace ... n=yssp_art
    http://www.northwestwholesale.com/video ... cement.asp
    2003 Marquis Euphoria - 400gal
    Mar 2007
    Coastalish 'down easter'
    4,160
    With an AG overlap liner about all you need is ~50 cloths pins. The idea is that you have the liner draped in the pool but keep it from touching the sides by holding it up with the pins. When the water gets high enough, the pins start popping off and you have to let a couple of inches of liner into the pool - it's fun to run around the poolpulling and replacing cloths pins .
    When you are ready to take on this project, just ask and I'll help you through it :thumright:
    Luv& Luk
    -Ted
    259
    Quote Originally Posted by waste
    Thanks Waste, I think it may have been one of your posts on the Pool forum that I saw a while back to just let the water seat the liner.
    I'll be sure to chime in when we are ready to start.
    Confer E9120 Steps
