Thread: filter bags for backwash
    Oct 2012
    Houston, TX
    186
    Last year when I was frustrated with water turnover in a small pool, plus messing up my small patio home yard by backwashing, I ran across y_not who suggested using the duda diesel filter bags. Just clamp one over the discharge hose and point it back into the pool.
    Since sand filters are typically 30-40 microns, the bag doesn't need to be really low micron. I figured that since lower micron bags cost about the same... why not go lower just because. On the other hand, I don't want to go too low and risk it filtering too slowly for a 1,600 gph pump and having it create too much back pressure and/or tearing, etc.
    Have any of you used the bags for this purpose? Does it work well for filtering out all of the backwash gunk?
    Intex UltraFrame 14'x48in - 3,900 gallons. Intex 1600 GPH combo Sand Filter/SWG Hard Plumbed w/Hayward skimmer, suction & return. Borates.
    And... 15k gallon kidney shaped gunite 1975 vintage. Hayward DE3620 filter + Hayward 750 pump.
    TF100 Test Kit | Pool School | Pool Math
    Jun 2013
    Manitoba, Canada
    153
    Re: filter bags for backwash
    Highly Doubtful. Just buya backwash hose (less than $10 for 30') and use that instead to drain it away from your patio area.
    22,553
    The general concensus is that they do work, but I'm not sure they're worth the trouble. In a pool the size you have the percentage of water lost when backwashing is greater than it is for a large pool so in your case it may be worth the effort to save some water.
