Thread: Hayward S360T: Plastic, not fiberglass.
    Pocatello, ID
    29
    The S360T filter appears to be made from injection-molded plastic rather than a fiberglass-reinforced composite. Is this ordinary plastic inferior? Should I paint it to protect it from UV? What differences can I expect?
    25K IG Vinyl / Pump: HP Tristar SP3207EE (as opposed to the confusingly different SP3205X7) / Filter:Hayward S360T2 (prev. SuperFlow PF-50) / Heat:6-panel FAFCO Ceiling solar heater
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Hayward S360T: Plastic, not fiberglass.
    If the s360t is the same tank material as the 244t then No it's a good tank. Fiberglass tanks are the ones where the resin breaks down and gets fuzzy and eventually start to weep water.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Pocatello, ID
    29
    Quote Originally Posted by X-PertPool
    Thank you for your reply. That makes me feel a lot better about the purchase. It's the "most boring" $800 I've ever spent, so I want it to at least last a long while.
