Page 1 of 2 12 LastLast
Results 1 to 20 of 28
Thread: Rain and storms
    May 2013
    Mckenzie, Tn.
    19
    Rain and storms
    All the rain we have been getting is killing me. Water is clear alge/dirt in bottom of pool. Please help! So much water I just get it right and more rain two or three days over full back again. Should I put in chlorine tabs in skimmer?
    18'x32'x8' in ground, 300lb sand filter
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: Rain and storms
    Do you have a full set of test numbers for your water?
    Chlorine tabs in the skimmer are not typically recommended. They can damage your pump or ruin your skimmer.
    -- Guy --
    May 2013
    Mckenzie, Tn.
    19
    Re: Rain and storms
    Not right now have not been able to test today. I don't use tabs.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Rain and storms
    I'm willing to bet that the algae/dirt you are seeing on the bottom of the pool is debris washed out of the atmosphere or carried in by runoff. I get a bit of that after a heavy rain. Of course, test results would give us a bit more insight.
    Would not place tabs in the skimmer. The concentrated acid/chlorine mix can be harsh on your skimmer and pump/seals. Would still chlorinate using plain, unscented liquid bleach poured in front of a return jet.
    May 2013
    Mckenzie, Tn.
    19
    Re: Rain and storms
    OK thanks that is what I have been doing. All this rain is so frustrating!
    May 2013
    Mckenzie, Tn.
    19
    Re: Rain and storms
    It seems hard to keep numbers right with all the rain. PH is good fc and tc is the trouble
    May 2013
    Mckenzie, Tn.
    19
    Re: Rain and storms
    I've had my pool probably 12 years this is the first year I have done it with liquid bleach all manually!I really do like the results but with all the bad weather it seems to keep me pretty busy.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: Rain and storms
    Sorry... I don't have rain this time of year... I will see some next October... LOL
    Good luck!
    -- Guy --
    May 2013
    Mckenzie, Tn.
    19
    Re: Rain and storms
    thanks for your help I do appreciate it. We are calling for rain the next five or six days about 40 or 50 percent chance.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Rain and storms
    Aside from FC, the rain normally doesn't impact water chemistry as much as many would think (although it will lower CH which is a good thing for most people). Continue keeping an eye on FC daily, though.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    Re: Rain and storms
    You're so lucky.... We had a whopping 5" of rain here in the last year. No help at all lowering my CH.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Rain and storms
    I bet there's a few people here would love to send you some of our rain, Richard320!
    30,424
    Re: Rain and storms
    For newbies reading this thread, it is important to understand that rain, unless it washes water INTO your pool from the surrounding area, should have little affect on pool water chemistry.
    The vast majority of pools are simply unaffected or influenced by rain, even a pretty heavy one.
    In a 48" deep pool (average) a 2" rainfall adds 4% new water so, even though this is an oversimplification, changes your chemistry by roughly 4%
    Algae on the bottom of a pool is not caused by rainwater but by lack of chlorination prior to seeing visible algae.
    Blackbeard, if you have clear water and algae on the bottom of your pool, you should be vacuuming and brushing your pool to remove as much as you can and then you should begin the SLAM process.
    read "The ABC's of Pool Water Chemistry" up in Pool School
    read "SLAM - Shock Level And Maintain" in the How To section of Pool School
    May 2013
    Mckenzie, Tn.
    19
    Re: Rain and storms
    sounds good thank you it seems like we get 2 or 3 inches of rain backwash to waste the water level back down check the, calls get everything right another 2-3 inches of rain vacuum to waste check the chemical seems like the chlorine level be low again get the Korean backup more rain and so on it seems like I can't keep the chlorine level up enoughand three or four days later after more rain and more vacuuming and more backwashing chlorine level is down again.
    30,424
    Re: Rain and storms
    blackbeard,
    Please spell check and punctuate your posts. I cannot decipher "Korean backup".
    Siri has been in the sauce again this morning and needs your personal help desperately.
    May 2013
    Mckenzie, Tn.
    19
    Re: Rain and storms
    Sorry about the typos, auto correct on voice text...when I get the chlorine back up a big rain then lower water again vacuum to waste backwash. Then 2 or 3 more inches! Empty fill empty fill and so on...seems like just diluting the chlorine level down.
    May 2013
    Mckenzie, Tn.
    19
    Re: Rain and storms
    Sorry again about the Korean backup, I cracked up when I saw that! Thanks for trying to help me!
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    Re: Rain and storms
    Removed post due to possibility of incorrect interpretation!
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    30,424
    Re: Rain and storms
    That's the very first step if you want to clear your pool.
  20. Back To Top    #20
    May 2013
    Mckenzie, Tn.
    19
    Re: Rain and storms
    my pool water is clear. The test kit I have is a Talor k-1004 my free chlorine parts per million is the two to four range my total chlorine parts per million is the three to six rangemy PH the 7.5 to 7.8 range.I'm not really sure how to test for anything else?there seems to be a small amount of algae growing in the bottom as the water is perfectly clear.about every 2 or 3 days this comes back after vacuuming and brushing. I thought the rain dilution had something to do with it?
