Thread: Cloudy Water now using bleach
    Jun 2008
    Pittsburgh
    4
    Hello I have a 24ft round 4.5ft deep poll 15,000 gallons When I opened it I had black water was able to clear it up now I have blue cloudy water. After reading this post I went to the bleach for chlorine I have finally been able to keep the fc level at 11 overnight running the pump 24/7. See a slight difference in the water how long will it take for pool to become crystal clear. Here are my numbers.
    TH-400
    FC-10
    PH-7.5
    TA-120
    CYA-50
    Thanks Wilssm.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Cloudy Water now using bleach
    Your numbers look good, what kind of filter/pump do you have and are you running it 24/7?
    Also can you post what your CC are?
    FYI, your CH is on the high end, especially for an above ground pool. Have you been using a lot of Calcium-Hypo shock treatments?
    It takes time for the cloudiness to dissapate after an algae outbreak, black water, huh? Ick.
    Casey's Avatar
    SW PA
    10,438
    I'd say bring your shock level up to 15ppm and hold it there over night.
    11 doesn't constitute a shock level and you may just have to go a little bit more until it clears.
    The bleach is also good because the powder forms can also cause cloudiness.
    Keep us posted! 8)
    I'd also watch your TA so it doesn't climb anymore. Maybe even try and get it down a bit to 100 with muratic acid after you get your water clear... might even help keep PH from going wild on you.
