Results 1 to 14 of 14
Thread: TA too high
    May 2013
    Chandler Arizona
    78
    TA too high
    My TA is too High at 190-200, I used pool calc to lower PH from 7.8 down towards 7.1. I have added the correct amount of MA per calc. PH doesnt seem to move much. Should I keep going? My PH seems stable. I thought TA acted like a buffer for PH swings? My TA is suppoed to be at 60-80.
    Intex Ultra Frame 18 x 9 x 52 rectangle. 4545 Gallons.
    12 in Krystal Clear™ Sand Filter Pump w/ GFCI.
    Krystal Clear Saltwater System™ w/ GFCI.
    TF-100 Taylor testing.
    K-1000 Taylor testing.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: TA too high
    How much MA did you add?
    Are you sure your ph was at 7.8 and not higher?
    May 2013
    Chandler Arizona
    78
    Re: TA too high
    well i cant remember the exact amount the calc said approx 16 oz. or so i think? My numbers are at home. I'm pretty sure my PH was 7.8 according to the taylor basic OTO test.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: TA too high
    I get 27 ounces of 30.45% of MA to move your 4545 gallon pool (with a starting TA of 200 ppm) from 7.8 to 7.1 ph.
    May 2013
    Chandler Arizona
    78
    Re: TA too high
    Hmmp, May be I have something setup wrong in my calc? I will verify the numbers I input when I get home for lunch. BTW I had to buy 14.5% yesterday to complete this task. no 29% available. Whic means now I have to double it.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: TA too high
    Quote Originally Posted by Ame
    Yep, then you would have needed 60 ounces...you can select 14.5% on the poolcalculator.
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: TA too high
    How fast is your pH moving?
    Yes, it is a buffer, but each pool seems to have it's own TA need, so while 70 is optimum for one pool, 100 might be optimal for another (like mine
    May 2013
    Chandler Arizona
    78
    Re: TA too high
    this afternoon I put in 4 cups of MA. PH went from 7.5 to 7.1. and TA from 200 to 150. does that seem right. I have to leave it at that till im back in town
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: TA too high
    That's close, though I would have expected a bigger pH movement and a smaller TA movement.
    38,251
    Re: TA too high
    Seems reasonable to need that much of the 14% MA to lower the pH from 7.5 to 7.1 with a TA of 200. According to the calculator, it should have required 40 oz of the 15% MA.
    I too am a little surprised the TA moved that much.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: TA too high
    Could it be the static testing error?
    Playing with the pool calculator, I come up with a starting TA of 150ish for that much movement, dropping to about 110.
    Or maybe I'm doing something wrong with the calculator.....
    Re: TA too high
    Smykowski, above you posted; (each pool seems to have it's own TA need, so while 70 is optimum for one pool, 100 might be optimal for another).
    How can I know where a pools optimum TA level is?
    36k, FNS plus 60 DE filter, in ground cement, 40-60GPM
    Jun 2012
    Howell, NJ
    977
    Re: TA too high
    Just keep lowering your pH when it gets high, and the pool will eventually settle at its happy spot for TA.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: TA too high
    Quote Originally Posted by JohnN
    This.
