Thread: Chlorine going up
    cood60's Avatar
    Jan 2012
    Virginia Beach
    82
    Chlorine going up
    Wondering what is making my FC rise
    Has been very stable all summer. The last week or so it has been creeping up about a 1/4 to 1/2 ppm per day
    A few days ago I started to lower run time. No change so I lowered % from 45 to 35, no help
    Any ideas?
    Current levels: FC-6, PH 7.6, TA-70, CYA around 50
    22'x40' IG, Freeform, 26K gal, Vinyl liner pool(2011), three returns plus two step jets, one slide, two skimmers, two LED lights, Stamped Concrete with Aqua PL-Plus Automation panel, Pentair Intelliflo VS, Hayward Pro Series High Rate Sand Filter 500lb, Hayward Turbo Cell T-Cell 15 (SWG) , Dolphin Robotic Pool Vac, Hayward Heat Pump.
    Re: Chlorine going up
    How has the weather been the last week? Cloudy weather could cause FC to rise.
    Another, less likely possibility, someone else is manually adding chlorine.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Another possibility...Has there been a sudden decrease in bathers? It could be a combination of several factors, including those that Jason mentioned.
    cood60's Avatar
    Jan 2012
    Virginia Beach
    82
    Yup, it has been cloudy, a fiar amount of rain, temps have moderated a bit as well and less bathers. A good problem eh?
    Thanks for the input
