Thread: Chlorine/CYA Table question
    Do the figures on the Chlorine/CYA table apply to a hot tub/spa or do they just apply to swimming pools?
    Hx2 Trainer 14 Swim Spa - 1425 gallons
    Cartridge filter, fiberglass
    Using TF100 test kit
    Atlanta, GA
    30,403
    Re: Chlorine/CYA Table question
    If your spa is covered, there is not the same correlation. CYA protects chlorine from sunlight....most spas get very little.
    I understand a covered spa would have much lower CYA levels needed. I was really asking whether the same min, target and shock FC levels would apply to a particular CYA level
    Atlanta, GA
    Mar 2007
    San Rafael, CA USA
    12,082
    With the spa covered (no light) and the water often very hot, the risk of getting algae in the spa is lower. The CYA level is usually kept lower as well at around 30-40 ppm. So while the chart might imply a 2 ppm FC minimum for 30 ppm CYA or a 3 ppm FC minimum for a 40 ppm CYA, I've seen many spa owners start with 1-2 ppm FC at the start of their soak and then dose for the bather load right after their soak so that they start with 1-2 ppm at the start of their next soak. As for in between soaks if spaced out, then the chart is reasonable at 2-3 ppm FC.
