Thread: pH rising faster?
    efm1972's Avatar
    Jul 2012
    Philadelphia, PA
    19
    pH rising faster?
    Split by moderator from HERE. Please start your own thread for your own questions. Thanks, jblizzle.
    I read through this string and have the same question. This is 2nd season with pool (pool was finished May 2012). In the first part of this summer, I really did not have the issue of pH going up so rapidly. It did go up, but I was only adding about 1/4 gallon Muriatic Acid about once a week. Not sure what changed (pool filter on the same 10 hours/day and we do not run our fountain, etc.), but I am now adding 1/4 gallon Muriatic Acid about every 2 - 3 days now. Any ideas? Here are my test results:
    FC = 5.2
    TC = 5.2
    pH = 7.9
    TA = 90
    CH = 260
    CYA = 40
    Thanks
    18,500 gallons, DE filter, IG
    Onyx Ansylbrite (colored) plaster
    Jandy Pump 1.0 HP, Zodiac Filter (flow rate = 120 gpm)
    Installed May 2012
    Re: pH rising faster?
    If your TA went up, that could account for the difference. Lower TA levels will have less PH drift.
    38,251
    Maybe the top off water is also at a higher pH and TA than before?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Any chance you got the "safe" fumeless acid, which is half-strength?
    38,251
    Quote Originally Posted by Richard320
    This could be a VERY valid explanation.
    efm1972's Avatar
    Jul 2012
    Philadelphia, PA
    19
    Thanks for all the responses to my question. I did check my Muriatic Acid, which I purchase from Home Depot and I can confirm that it is not fumeless. Also, when I fill my test bottle, I do so from the same spot in the pool and from the same depth each time. After looking at my test log (yeah, I keep a spreadsheet of all my pool water tests), it is most likely due to a rise in Alkalinity. For the first part of this season, I had kept my TA in the 80 - 90 range. For some reason, I added enough Baking Soda to take TA to 110. Now that it is back down around 90, I am not adding Muriatic Acid as frequently.
    Thanks again.
    Installed May 2012
