Results 1 to 7 of 7
Thread: Cya test takes half a bottle?
    May 2013
    Santa Barbara, CA
    10
    Hi,
    Just starting to test my newly filled pool (city water) with the walmart 6 test kit and found the following:
    FC: 0
    Cya: 0
    Ph:7.6
    Also, the cya test took half the bottle of test chemical as part of the test. At this rate, I'll go broke
    Performing cya tests.
    Would you recommend that i add muriatic acid to raise cya?
    So far ive only put in one 128oz bleach 8%. The FC still shows 0.
    Please let me know what it usually takes to show minimum levels, thanks!
    15x30 Sharkline Heritage AGP, 8000 gal
    Pentair SD80 Sand Filter, Pentair 2 speed .75 HP pump
    Self-built July 2013
    BBB (Just bleach) so far
    Re: Cya test takes half a bottle?
    Some of the test kits come with very small amounts of the CYA reagent. The HTH Six Way, Taylor K-2005, and K-2006 all come with 0.75 oz of the reagent, which is enough for two or maybe three CYA tests. You can purchase more CYA reagent for reasonable prices, though there is often a shipping charge.
    With CYA at or around zero you will lose all of your chlorine to sunlight very quickly. Muriatic acid does not raise the CYA level, it lowers PH. You want cyanuric acid to raise the CYA level. Cyanuric acid is often sold as stabilizer or conditioner, check the label and make sure it contains 95+% cyanuric acid.
    38,262
    Back to Pool School
    Muriatic acid lowers the pH ... it does not add CYA. CYA is Cyanuric acid aka stabilizer aka conditioner
    With 0 CYA, you will lose most of the FC to the sun in a matter of hours ... get some stabilizer dissolving in a sock in front of the return and keep adding bleach.
    Now you know one of the reasons we recommend the TF-100 over the K-2006 or the HTH kit ... you get more of the reagents you need. And of course you get the important FAS-DPD chlorine test.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,971
    Well....you wasted that reagent, because tap water has no CYA in it. To add CYA, you add CYA, also known as stabilizer or cyanuric acid. Without it, any bleach you add to the pool will be lost to the sun in a couple hours.
    Since you built the pool yourself, you sound like a do-it-yourselfer, in which case, I recommend reading Pool School. Just the first few articles will give you a wealth of knowledge, and the ability to use and understand the pool calculator.
    May 2013
    Santa Barbara, CA
    10
    Thank you very much for the quick responses! Will update with new numbers when available.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    You should also note that granular stabilizer is very slow to dissolve (use the sock method in front of a return), also note it can take up to a week for the CYA to show on the test.
    x2rider's Avatar
    Jun 2011
    Bartlesville, OK
    212
    Back to Pool School
    K-2006 is FAS-DPD, but yes, the reagents go fast. I replace them with 2 oz bottles.
    27000 gal 18x36 rectangle In-Ground built in 1978
    Vinyl liner, 3/4hp Hayward Super pump, single speed 3450rpm
    SWG: Hayward Aquarite AQR15
    Sand Filter: 300 pound sta-rite T-240BP-1, 3.14 sqft surface area
    K-2006 Test kit
