Thread: How long should I be letting the pool run?
    How many hours a day should I be letting the pool filter run for? Since I opened my pool for the first time I've been running it 24/7 but hydro rates are high during the day. Any help would be great.
    Thanks, Johnny
    IG
    Brand New
    Re: How long should I be letting the pool run?
    Try How to Determine Pump Run Time in Pool School.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    This is one of the most common questions here. You can study the article posted above, or check out the previous discussions.
    Thanks for the help, this might be a stupid question but does the heater have to be off when the pool is not running. It's a Rheem gas or do I just lower the heater temperature?
    IG
    Brand New
    22,550
    The heater should definitely be off when the pump isn't running. It has safety devices in it to insure it shuts down when there's no flow through it and if it's on a timer, the timer should have a firemans switch too.
