Thread: Feedback on steel walls manufacturer needed
    Ukie's Avatar
    May 2012
    Export, PA
    83
    My PB is using steel walls manufactured by International Swimming Pools, Inc from New Brunswick, NJ, http://www.internationalswimmingpools.com
    Any feedback on the manufacturer?
    Lagoon shape, 23,600 Gal, steel walls by International Swimming Pools, "ultra-seam" liner by Latham, Pentair 011018 IntelliFlo 3HP Variable Speed Pump, PentAir CCP420 filter, Heat Siphon Z575HP, PentAir IC40 SWG, 2 LED Lights (Pentair Intellibrite 5G, 110V). 4 x 1.5’’return lines, 2 x 2’’skimmer lines, 1.5’’ waterfall line. All plumbing is "TigerFlex" pipe, all lines plumbed individually. Deck: travertine glued over concrete.
    Ukie's Avatar
    May 2012
    Export, PA
    83
    Re: Feedback on steel walls manufacturer needed
    Anyone?
    Jun 2013
    Southern Ohio
    86
    Don't think I can help you too much on your manufacturer. I'm doing a DIY right now and researched quite a few and ended up purchasing from PoolWarehouse.com Their steel wall pools are manufactured by HydraPools using Samson Steel. I know a lot of the pools in our area are built with the same walls. Seems as though when you look at a lot of the steel wall kits being built, the panels all relatively look the same. I guess the true measure would be the warranty on the walls, the thickness, and coating.
    18x36 Lagoon vinyl IG DIY sport bottom 3.5-5-3.5 18K gal. Hayward Tri-Star 1 1/2 HP 2 Speed, Hayward 27" 350lb. sand filter, Hayward Aquarite w/ T-15, 1 skimmer, 2 returns, 2 step jets, 4 deck jets, 1 waterfall, TF-100
