Results 1 to 8 of 8
Thread: Does new T-15 cell come with flow sensor and ...
    Does anyone know if I buy a new T-15 cell if it comes with a flow sensor? Also I notice there is a GLX-FLO and a GLX-FLO RP. Does anyone know what the difference is between the two?
    Thanks a million folks,
    38,460
    Re: Does new T-15 cell come with flow sensor and ...
    The cell alone does not come with the flow sensor or the unions to mount the cell.
    I think the GLX-FLO-RP is just the sensor and the GLX-FLO is the sensor installed in the required tee fitting.
    The P-KIT includes everything you need to install the cell.
    Is this a new install or a replacement?
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    The flow sensor is separate from the cell.
    The GLX-FLO RP is a replacement flow switch. It is just the flow switch without the T that it installs in.
    chiefwej
    MBG75's Avatar
    Jun 2013
    Long Island
    184
    I just ordered a Haywood t-15 cell Friday from pool supply world. The flow switch was included in the price. But was a separate part number on the order.
    25k IG vinyl SWG Haywood 4830de 1.5hp TF-100
    This will be a replacement. As of now the flow sensor / light does not work on my current system anymore.
    I have a brand new main board just replaced this year. The flow sensor light did work after installation but then stopped a few weeks ago. The board clicks when it is on and the numbers adjust accordingly showing V and amperage but the chlorine production just isn't where it should be even on super chlorinate. The cell is 5 to 6 years old to begin with so my thought is just replace both now and go from there.
    Quote Originally Posted by MBG75
    Is this the one?
    http://www.poolsupplyworld.com/Hayward- ... CELL15.htm
    This price does not include the switch though.
    MBG75's Avatar
    Jun 2013
    Long Island
    184
    Quote Originally Posted by kbp911
    Is this the one?
    Mine was $576. Looks like the cell plus the flow kit.
    http://www.poolsupplyworld.com/Goldline ... -P-KIT.htm
    38,460
    It is pretty rare for these flow switches to fail I think. Sounds like you have no need for the unions or the tee for the switch. Might be cheaper to just find the cell and flow switch (if needed) separately.
    It is also pretty easy to bypass the flow switch I think to determine if it is indeed the problem.
