Thread: Adding DE to Sand Filter - 1 PSI low vs high speed on pump
    May 2013
    North East Ohio
    959
    I tried searching, but could not.
    Most of my major construction is done, my pool is sparkly clear - expect for a ton of tiny debris. My sand filter is doing great, but I want to add DE to get her perfect.
    Question is - is the 1 PSI rise on LOW or HIGH. I normally run on low at 2 PSI vs. high at 10 PSI - when adding DE what speed ?
    Thanks
    14,750 GAL IG Fiberglass (16 x 33) NE Ohio || Jandy 1HP 2 speed Pump || Waterco MultiCyclone 16 Centrifugal pre-filter (removed due to not working with sand filter) || 30" 575 Lb. Sand Filter || AquaCal 140K BTU Heat Pump || Solar Cover || Inter-fab Adrenaline Slide || GLI Monsoon Solar Cover Reel || K-2006C Test Kit || BBB with Liquid Chlorine Stenner Injection || Rayner Mighty Mesh Winter Cover
    22,550
    Re: Adding DE to Sand Filter - 1 PSI low vs high speed on pu
    That recommendation was written before the popularity of multi-speed pumps, so it should be on 1 psi rise on high speed.
    May 2013
    North East Ohio
    959
    Gotcha - thanks much!
