Thread: TA recommendation questions
    4myBitsy's Avatar
    May 2013
    Milford, CT
    37
    My TA is 140. Do I need to do anything about it? I have read a couple different recommended levels & am not sure what to go by, my TF-100 directions say between 100-120 and TFP says 70-90+. I am now over both recommendations, most of the year it hung out around 120. I do not have a problem with my PH going up. I actually add Borax about once a week because it tends to go down. I also aerate sometimes instead to bring up the PH since the borax raises the TA some and mine has been on the high end. Thanks in advance for all your help.
    AG 24' round 52" walls, 12,900 gal
    Proline 22" sand filter, Proline 1hp pump, vinyl liner, Taylor TF-100 test kit, TFPC
    30,419
    Re: TA recommendation questions
    Then leave your TA right where it is. You'll be just fine and it seems your pool is happy there.
