Thread: Two Ports in skimmer bottom. Gizmo to activate second port
    Aug 2008
    Western Connecticut
    5
    Ok, I know there is a post already about two port skimmers but it does not address my problem. I have two skimmers and both have two ports. I also have a main drain which I have never been able to get to work. One of my skimmers has a gizmo that covers the two ports. It looks like a giant sausage cut in half lengthwise, with a port on top and a sliding cover to adjust the size of the port opening. Inside the sausage is a paddle to regulate the skimmer port usage. The gizmo screws into the skimmer bottom and it is used to regulate the amount of suction that goes to skimming vs the suction on the secondary hole, which diverts suction to the main drain (their are instructions on the sausage that confirm this).
    My question is this. I need another of these sausage parts. Does anyone know what it is? Part description, number, manufacturer, or anything; so I can order one for the other skimmer. I believe this is the only way I am going to get the main drain to work. If you know the answer, can you text the information to my cell (203-217-2652)?
    Inground Pool 40x20 Vinyl Liner
    Hayward DE Filter and pump
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Two Ports in skimmer bottom. Gizmo to activate second p
    Using the term gizmo in this application is going to lead to confusion, because there is a device that plugs into the skimmer for winterization that is actually called a gizmo.
    What you are looking for is called a diverter. In Pool School, there is a Visual Encyclopedia of Pool Equipment that is useful for finding things when you don't know the name. Here is what I think you are looking for:
    Aug 2008
    Western Connecticut
    5
    That is it!
    Admonishment accepted, but I still don't know who makes it, the model number, etc. need to order one and picture of what I can see outside isn't helping.
    Do we know who makes this product?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Quote Originally Posted by gmessier
    That is it!
    Start looking at the rest of the skimmer for any brand names or part numbers. Once you have a clue, it should be easy to track down the missing part.
    SW Indiana
    9,199
    That is it!
    The one in the picture is a Hayward.
    http://www.amazon.com/dp/B004VTG7EE
    22,553
    That particular one is a Hayward Skimmer to Main Drain SP1082GV.
