Thread: Easy Touch temperature sensor
    May 2011
    No. CA
    111
    My Easy Touch is about 2 years old. The OEM water sensor went bad in March.
    I replaced it with an aftermarket versions (Optimum Pool Technologies) and replaced it in March, and the replacement failed a couple of days ago.
    The air sensor is still accurate and the on-roof solar sensor seems to still be working.
    Luckily, I ordered two to have a spare, but after installing it, I'm wondering, are these sensors problematic? or am I having bad luck? or could something be wonky with my install? or ... ?
    Pool IG 17,000 gallon (33 x 16) Spa IG 700 gallon - under renovation
    Sta-Rite IntelliPro VS 3050, Pentair Easy Touch 8, Intellichlor IC40, Pentair FNS Plus 60, TF-100 Test Kit w/ salt test
    Pentair Intellibrite 5G Color LED, Polaris 360, Lars Lx400 NatGas heater, Fafco Solar panels
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    414
    Re: Easy Touch temperature sensor
    May be too close to the pump and getting too much pressure maybe during priming.
    And yes they fail. I have replaced mine once in three years.
    25k 20x40 Gunite w/ integrated Spa & Caribbean Blue Plaster, Curved Bluestone Coping, Deck Jets
    Pentair Easy Touch/Wireless, Sta-Rite Intellipro SRVS Pump, Intellibrite Lights, & Pentair IC40 Cell, Sta-Rite 450sf Cartridge filter
    Heated from Central Boiler - Outdoor Wood Furnace & Triangle Tube Max Heat Exchanger
    ColorQ Pro
    TF-100
    Nov 2009
    Indialantic, FL
    323
    Have no idea if blakeusa's answer is correct (seems plausible), but I experienced the same phenomena. I have all Pentair equipment - air and solar still working after 3 years - water sensor near pump failed after 2. My pool install has reasonably simple plumbing - usually running the VS 3050 @ 900 RPM, stepping up to 1350 RPM when the solar is demanded (only spring and fall here in Florida).
    Geometric 16X36', 16K gal, shotcrete, exposed aggregate plaster, acrylic coated concrete deck/cantilever coping;
    Pentair equipment suite (EasyTouch w/wireless, 2 Intellibrites, Intelliflo VS-3050, C&C 200 Filter, IC-40 SWG);
    Heliocol solar panels, Rocky's Roller, Blue Diamond robot
    22,542
    They appear to be a 10K thermister in a plastic body. Can some of you tell me exactly how they fail?
    May 2011
    No. CA
    111
    They fail to report temperature accurately. Not sure exactly how they fail since I haven't taken one apart.
    First failure reported the pool to be a steamy 105 F in march.
    Second failure reported the pool to be a tepid 70 in July when it was 85F
