Thread: Rock hard deposits inside of iron waterfall pump
    If never heard of anything like this but it is REALLY hard stuff and all over the inside of the pump. It is also discharging a redness that looks like rust. It is not rust and I have acid washed, scraped and bashed most of it off and the paint surface comes out new underneath. Are these barnacles? Or maybe black algae that has run wild?
    What do you think?
    Lid
    Blue Paint Underneath
    All those granules are rock hard.
    Let me know if the flicker photos do not come through.
    Silver Maple Leafs
    The Royal Canadian Mint uses the finest coin blanks in producing these coins,
    wherein The Canadian Silver Maple Leaf is used as the standard by which all
    the other silver coins are measured.
    38,371
    Re: Rock hard deposits inside of iron waterfall pump
    They did not come through. I edited the first one so you can see what I did (and change the others). You only need the JPG URL in the IMG tag and you need to close the IMG tag.
    Well, I had fixed the first one and then you must have edited at the same time.
    Make the first one look like this:
    Code:
    ****, I was trying to fix them also and undid what you did sorry. Can you re do that?
    Dan
    Silver Maple Leafs
    38,371
    Use my code snippet above to figure out what you have to do. You can use the "Preview" button to see if it works without posting each time.
