Thread: Proper ground prep to keep level?
    Jun 2013
    Manitoba, Canada
    153
    3 years ago we bought our Intex inflatable 18'. I leveled the ground off, put a tarp down, and then put 4" of sand down inside a 2x4 wooden octagon ring. I then compacted the sand with a power packer, leveled it all off again, and then put another tarp on top of it.
    The first year the pool was bang on level. The 2nd year when I put it up, I had to level the one end 1-1/2" down as it had lifted for some reason. This year I leveled the sand off again, compacted, and now 1/2 way through the season its almost 3" out of level on the one end (same end as last year).
    For some reason the ground is shifting. We want to get a hardwall AGP in the next couple of years, but I do not want this happening. What is the best thing to do?
    The sand is not washing away, everything looks fine. It just looks like the ground is shifting.
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    Re: Proper ground prep to keep level?
    How did you level the ground. Did you dig the high side down, or fill in the low side?
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    Jun 2013
    Manitoba, Canada
    153
    Dug down the high side
    Jun 2013
    Manitoba, Canada
    153
    Here is couple of pictures showing how much the ground has lifted this year.
