Thread: Kreepy Krauly Classic for concrete pool
    New2water's Avatar
    Jun 2011
    Stockton, CA
    53
    I have to replace my old Kreepy Krauly but when I look at new ones, there is a different model concrete pools. The old one seems to be for tile/vinyl pools. I have not had any problem with it (other than it spends more time on walls than on the floor). Did I have incorrect model all this time or should I buy the same?
    18K gal in ground, Plaster, three 1 HP WhisperFlo WFE-4 pumps (Pool, Hot Tub, Waterfall), 320 sq ft cartridge filters, MiniMax Plus HP 400 heater, TF-100 test kit, Kreepy Krauly Classic cleaner
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Kreepy Krauly Classic for concrete pool
    I would go with design specific. Maybe it would spend more time on the floor...and after all, you do want it there too.
    Essential Links:
    Aug 2013
    Hurst, Texas
    7
    Wow, did you run over it with your car? I didn't think you could wear a Kreepy out!
    The only difference is the Skirt - Starfish is for Concrete/Gunite/Plaster - Round is for Fiberglass & Vinyl
    The Starfish Skirt does a good job for me, and seems to last much longer then the Round Skirt (the ribs make it thinner)
    30k - IG - Plaster - Triton 60 Sand Filter - Zeolite Media - 1.5 h.p. Single Speed - Kreepy Krawly
