Thread: Pump Run Time
    Pump Run Time
    I am at a lost to figure how long to run my pump on a new pool..
    My gals are 13180..
    None to little surface debris
    None to little bottom debris
    I have almost no vegetation that can get into pool except some flying debris occasional..
    I have a Jandy VS 2000 pump.. I am running it at like 1800 RPMs for 6 hrs and 3150 for 4 hrs..
    Is this way to much.... I'm not smart enough to figure the jandy turnover charts..
    Pool has been perfectly balanced and sparkling clean..
    I also have only one skimmer and a cartridge filter..
    Any advice is appreciated..
    13K IG Pool with Raised Spa
    Jandy E Pump- 2HP Variable Speed
    Jandy CV460 Cartridge Filter
    Jandy LXI 40,000 Heater
    Polaris 9300 Robot
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Pump Run Time
    It is actually pretty easy. Start with this and see if you have any questions: pool-school/pump_run_time
    Mark
