Thread: need new equipment and in need of advice.
    I just bought a repo home from a flipper. He put craigslist equipment on the pool in order to sell it. the original equipment was stolen. The filter is way undersized and has a blow by issue. I'm live in the mountains outside Yosemite so leafs dust and dirt are a big issue. I will be purchasing a very large DE filter. Most likely either the Hayward progrid 72 or the Pentair FNS 60. Rotary or pull back wash valve?
    The pool is about 28,000 gal with 2 sheer descents and no spa with 2" plumbing.
    I'm looking to replace the pump as well. the current one leaks and cavitates. There is a lot of hype of pumps. Both Pentair and Hayward have so many the choice is staggering. Even if one considers only the VS pumps. Any advice?
    I'm also leaning toward a SWC but again the choices are staggering.
    Who is the best online retailer for prices?
    Thanks for the advice.
    Bob
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: need new equipment and in need of advice.
    Welcome to tfp, scratchnbell
    For your size pool, we recommend a minimum of 78 sq. ft. DE filter. The Multiport style (I think that is what you mean by rotory) allows for more circulation options than the push/pulls.
    Quote Originally Posted by scratchnbell
    We will need some more details like any high volume water features and some plumbing details (number of runs and diameter).
    All plumbing is 2 inch. The longest run is 40 feet. There are 3 suction lines. One for the skimmer, one for the pool cleaner and one for the slip drains.
    There are 4 return lines. One for splits to 3 return nozzles, one each for two 24 inch sheer descents, and one for the stolen slide.
    If i can get some recommendations for a vendor i can order the filter and continue to research the pump. The pump works. The filter is not working at all.
    Thanks
    Bob
    30,421
    We have no suggestions for a vendor. There are so many good and bad stories around we do not endorse anyone.
