Thread: signature created I hope
    rlefig's Avatar
    Apr 2013
    Reading, MA
    200
    Getting closer on getting into house. I found info on pool today
    The pool was built in 1971, older than I had hoped. it is kidney shaped and 31x16. I think 16 is its widest width according to paperwork. The average depth is 5.5 feet. Just as a funny in 1971 it cost $3500 to install. Wth these dimensions I guess it is between 19k and 20k. Please correct if needed.
    The pool is a major swamp. Some of the decorative tiles are missing. It does hold water. It was last opened maybe 3 -> 4 years ago.
    I needed a new pump, so I bought a used one back in May when the process of buying this short sale just started. It is a Sta-rite System3 S7m120 with 300 Sq ft of filter. Hope that is a sufficent size. Also a 1HP pump as well.
    I have a test kit in waiting as well since June
    Thanks
    rob
    1971 Gunite 31x16 IG Kidney shape pool approx 18000 Gallons
    EcoFinish Blue Lagoon
    Sta-rite System3 S7M120 Cartridge Filter
    A.O. Smith 3/4 HP motor, starite pump
    TF100 test kit
    Beens's Avatar
    Jul 2013
    Virginia Beach, Va
    1,171
    Re: signature created I hope
    I'm going to lurk on this thread... can't wait to see some pics! Good luck!
    18' x 48" (42" water depth) Intex Metal Frame 6,700 Gallons
    Hayward Power-Flo LX 1.0 HP pump
    Hayward Pro Series S166T Sand Filter
    Original Intex Floating Skimmer
    rlefig's Avatar
    Apr 2013
    Reading, MA
    200
    August 23rd is the date, too bad summer will be almost over by then
    TF100 test kit
    I'll be lurking, too. Watching renovations is fun.
    Filter size is great. (I use that same filter.) See this sticky in the Pumping Station area of the forum: hydraulics-101-have-you-lost-your-head-t915.html
    What is your pump's maximum flow rate?
    Outdoor 14,000 gallon IG plaster pool built in 2000 with spillover spa, 2 hp WhisperFlo pump with MagneTek motor, Sta-Rite cartridge pool filter with 300 ft2 filtration area and 0.33 gpm/ft2 filtration rate, Aquabot Rapids 4WD robotic pool cleaner, Raypak digital gas heater, and Intermatic mechanical timer located in the Dallas-Fort Worth metroplex
