Thread: Bubble in liner above waterline
    I developed a bubble in the liner about 4 or 5 feet long above the waterline. It's smooth and wrinkle free on the wall everywhere else. It's an overlap liner. My question, can I remove 2 sections of rail and stabilizers down to the coping so I can pull the liner tight while the pool is full? Thought about going around the entire pool with a couple of ratcheting straps to hold everything in place. Or do I need to drain some water? Thanks.
    18'rd vinyl AG 8000ga
    1hp Hayward Powerflo Matrix
    Hayward 90sq ft EC900 Cartridge Filter
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Re: Bubble in liner above waterline
    Just pull a couple of sections at a time off. They help keep the pool round but aren't really structural otherwise.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    Thanks, only need to pull off 2 sections to fix it. But I wasn't sure if I would be able to put it back together with the water pushing on it.
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    The wall actually holds the weight, the top/bottom rails force it to be round. The top seats help keep it stable but don't really provide support. Might have trouble if someone is cannonballing while trying to reattach but otherwise should be okay.
    Dan D
