Results 1 to 13 of 13
Thread: TF-100 Kit on the way......Question in the mean time
    Jul 2013
    Santa Fe, Texas
    15
    Ok,
    I have my first pool up a little less then two weeks. I already ordered the TF-100 but it is not here yet. Anyways my question is I have well water with metal in it, I used Jacks Magic "Blue Stuff" a whole 32oz bottle. Man worked great over night and pool was looking good. It only lasted two days and went back to the way it was. While I don't mind putting more in it can get expensive every 2 days which I did add another half bottle......Here is my latest test from LESLIE'S while I wait on my TF-100. I also brought my FC up the next day after I adding Jacks. (FC was 3 when I added Jacks)
    FC 6
    TC 6
    CA 50
    TA 130
    PH 7.0
    1) What can I do to make it last longer
    2) Is there another product other then Jacks ($26.00 32 oz) that is less expensive?
    3) Is that normal to have to keep adding that much every few days?
    Eugene, New Pool Noobie
    Intex 12' x 24' x 52" AG 1600 gph Sand pump Krystal Klear,8400 Gallons
    Installed 7/27/13 TF-100 On order "Freshman in Pool School"
    38,539
    Re: TF-100 Kit on the way......Question in the mean time
    I think there are other sequestrants we would recommend for you. Have you read this article: pool-school/metal%20stains
    It is normal to have to keep adding it, although I am not sure how often. And when you raise the FC level, that will have a tendancy to make the discoloration come back.
    Jul 2013
    Santa Fe, Texas
    15
    I have read the article but was hoping to get somebody that has experienced this problem before. I thought it turned pretty dang fast, so hoping once I get enough in there then a weekly maintence program with just a few ounces added every week will work.
    38,539
    It looks like you have a lot of metal in the water based on how greent he water turned, so you may need to use more sequestrant than others ... hopefully someone with similar issues can chime in.
    30,432
    I believe that green color to be triggered by the addition of chlorine. It precipitates the iron out of your water and, the good news is, if you run the filter 24/7, I think that iron (just that which precipitated...not all of it) will filter out.
    In time, the water will turn back to blue and you will have less iron to deal with. I can't tell you how long that will take (in my pool, 3 days is pretty close) nor can I tell you for a fact I am correct.
    If you have one, can you add your refill water through a water softener? That'll eliminate the problem in time.
    Jul 2013
    Santa Fe, Texas
    15
    Any suggestions on other less expensive products other then Jacks that works?
    Jun 2012
    Howell, NJ
    977
    I would just let the filter take care of the iron, assuming that the Intex filter can handle it. That is what I do when I have to add water to my pool. It usually clears up in a few days.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    Jun 2013
    SpringHill FL
    415
    I have mild iron in my water so when i fill i run the hose through a homemade prefilter of craft batting and a tube sock it removes most of my issue. You might try a similar method fastened over a return to help filter out some of the stuff
    Nathan
    15x30 gunite 18k gallons Hayward star clear plus 120sqft cart
    Jul 2013
    Santa Fe, Texas
    15
    I will give it a couple days and let the filter run 24/7 and see what happens. I left a ball floating in the water and boy it did not take long to get a ring stain around it (24 hr)
    Jul 2013
    Santa Fe, Texas
    15
    RE: Update TF-100 Kit on the way......Question in the mean
    Ok, TF-100 should be here hopefully tomorrow or Saturday if UPS delivers. In the mean time should I add Muriatic Acid to lower the PH and some Bleach for more Chlorine? Or just wait for the TF-100 so I can get better results? Here are todays pic. & cheapo test results
    30,432
    If you chose UPS as the shipper for your TF-100, you should have received a "shipped" notice from them with an expected delivery date (which they meet about 99% of the time). Check your email you provided us when you ordered. Unfortunately, they do not deliver on Saturdays (without a HUGE premium)
    Jul 2013
    Santa Fe, Texas
    15
    Expected date is tomorrow by the end of the day.
    Thank you Dave.
    Jul 2013
    Santa Fe, Texas
    15
    About to do my first SLAM
    mod edit: Please keep you posts on this issue in the same thread so that we know the history. Thanks, linen
    Ok, my new test kit will be here today. If everything is right I am going to start slamming this afternoon. Here is my question, Since I have a lot of metals in the water and I am sure the bleach will affect my sequestrants agents already in the water. What should I do about it? Slam it and wait for the to levels of FC come down and add some sequestrants?
