Thread: Fence Review
    Jun 2013
    Southeast Pennsylvania
    125
    Fence Review
    Hello,
    I am researching 4 local fence installation companies and they all deal with different fence manufacturers. The, manufacturers are Alumi-Guard, Colonial Aluminum, Ultra, and Delgard. I am installing 250' of black aluminum fencing. They are all in the same ballpark with the exception of one installing the Ultra being a $1,000 higher.
    How do I determine which fence (not installer...the actual fence) is the best??
    Doug
    13,500 Gallon Gunite Aggregate Finish, DE, SWG, 2.0 HP pump, 1.0 HP pump for 3 Sheer Descents
    Jun 2011
    Long Beach, CA
    2,790
    Re: Fence Review
    You can ask about the thickness of aluminum, grade of aluminum, and look at the quality of welds. Also, the type of paint they use, powder coat might be the best option?
    Jun 2013
    SpringHill FL
    415
    Re: Fence Review
    I agree thickness of the aluminum is key, powder coat is better than paint. I would ask the individual installers to show you a sample section of the fence they would be installing on your property, so you can physically see and feel if its what you want to spend your hard earned money on
    Nathan
    15x30 gunite 18k gallons Hayward star clear plus 120sqft cart
