Thread: Average pressure too low??
    Jun 2011
    Central Iowa
    105
    Newbie here. We have a new pool with pump/filter. I see many posts and articles about pressure running at least 10 on a normal day. Ours from day one has been running about 4-5psi with the pump on low. Is that normal or ok? Everything seems to be working ok though and so far pool is staying clean. Is it just due to low speed of pump and large pipes? We should then backwash once our pressure hits 6-8? Thanks all!
    27' x 54" AG Morada RTR/19,300 gal/ 1hp-2spd Hayward Power-Flo Matrix/Hayward 256T sand filter
    38,246
    Re: Average pressure too low??
    Mine registers less than 4 psi on low, completely normal. You should use high speed pressures for determining when the filter needs to be cleaned.
    tcat's Avatar
    May 2012
    Austin, TX
    730
    My low is 7, but I think my filter needs cleaning. I'd backwash on high, see what pressure on high is with clean filter, then add 20-25% to that and check high readings for "time to backwash".
    IG pebble, 15,000 gallon
    48 PentAir DE Filter with backwash valve
    PentAir Whisperflo pump with 1hp 2-speed motor
    Aquabot 4WD, Poolskim
    Intermatic Dual Timeclock with freezeguard
    DIY chlorine feed
    BBB
    Jun 2011
    Central Iowa
    105
    Ahhhhh ok thank you. I'll check it on the high setting.
