Results 1 to 10 of 10
Thread: Grill and vinyl fence
    I am not sure if this is the right place to post this question. I plan to someday build an outdoor kitchen but it isn't in the current budget. The place I want to put my grill is about 18" from my vinyl (pvc) fence. Will the heat from the back of the grill be too hot for my fence? If so, has anyone built some type of heat block to protect the fence?
    16x24 IG Vinyl Liner coming soon!
    Feb 2008
    Denton, TX
    5,061
    Re: Grill and vinyl fence
    18" is not far at all and I too would be worried about radiant heat damage. Not sure what you could or would want to put between the fence and your grill though.
    Jun 2013
    SpringHill FL
    415
    18" is too close to the fence for the grill to not melt it. You could build a heat block with two posts (metal would be best but wood would suffice) then get a couple pieces of cement board and screw them to the posts. You then could tile the sheets or use a stucco finish on them
    Nathan
    15x30 gunite 18k gallons Hayward star clear plus 120sqft cart
    Not the exact same but the back side of my house is vinyl. I at times when raining have had my grill with in 6in of my siding with no ill effects. Now this was only a few times. Repeatedly it may have an effect.
    18x36 Grecian Vinyl; 8' Roman steps w/t 2 spa jets; cozy cove w/t 6 spa jets; 2 MD, 1 Skimmer, 3 returns; Hayward Ecostar, 30" Ranger sand filter; Hayward color logic 4.0 LED light; Hayward aqua logic; 2" PVC pipe 4 Jandy Valves
    Jun 2013
    SpringHill FL
    415
    Lol i am in the construction industry. You would not believe how many jobs i get replacing burnt/melted vinyl siding from grills too close to the house. You are lucky to not have sagging siding panels from the heat
    Nathan
    Donldson's Avatar
    NW Ohio
    2,898
    You probably won't see any immediate changes, but over time it will likely discolor and/or warp slightly. FamilyGuy has a good plan. Really anything that could block and absorb the heat would be good, even just plywood in between the grill and fence. It could absorb the heat and would be a sacrificial item, able to be removed and replaced when needed. I'm just pointing out a simple (and cheap) fix, putting some work in to something that will look nice and last is never a bad idea.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Aug 2010
    New Caney, TX 77357
    184
    JeepMann - I'm not clear, are you talking about putting a stand-alone grill close to the fence now or are you talking about the location for the grill in your future outdoor kitchen build or maybe both?
    20K gal, inground with attached spa, pebblefina plaster (bella blue), flagstone coping, moss rock waterfall, Sundek - Indian wheat, (2) Jandy PHPM2.0 (filter pump and waterfall), Jandy DEV60 DE filter, Polaris 280 pool cleaner, Polaris Halcyon PB4-60Q booster pump, Polaris 1.5 HP Air Blower, (2) Jandy WaterColors LED lights, Jandy LXI400P Heater, Jandy AquaPure PLC1400 SWG, Jandy AquaLink RS PureLink Controller and PDA.
    Quote Originally Posted by Stevereno
    Both actually. The spot were I plan to put my stand-alone grill would also be the future spot for my outdoor kitchen when I have the funds for the project.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Quote Originally Posted by FamilyGuy
    My sister-in-law got her grill too close to the vinyl siding on her house one time and melted the vinyl siding.
    JeepMann, I would suggest keeping the grill at least 36" from the fence. If that's not doable due to space constraints and your grill will be a built-in, the next best thing would be to install a ceramic wind break (also serves as a heat shield) behind the grill as I did in the enclosed pic (shown at our former house). If you are going with a free-standing grill, then you could install a cement board barrier between the back of the grill and the fence.[attachment=0:zcmxvi6p]S4010238.JPG[/attachment:zcmxvi6p]
    Thank you everyone for you input. I am going to build some type of heat shield behind the grill. I will take some pics and report back after it is complete.
