Thread: Trting to deep clean the sand filter
    Took off the lid to the sand filter, placed the hose into the sand bed, turned water on filled to the top. I went inside and when I came back out water was not running over the top. Is there a reason as to why? Where should I have my multiport turned to closed position?
    25K
    Sand Filter
    Bleach is my source to chlorinate with
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Re: Trting to deep clean the sand filter
    Quote Originally Posted by CalebsDad
    That would be my guess. All you're doing right now is filling the pool via the filter.
    But in the closed position It quit coming over the top of the sand filter I am lost fo sho!!!
    25K
    Sand Filter
    30,415
    If the multi-port is closed and working correctly, there is no other place for the water to go except out the top.
    Since it is apparently not, your multi-port must be letting water pass through back to the pool.....there is really no other path.
    You will need to disassemble the multiport and probably find the spider gasket damaged or misaligned.
