Thread: pump electrical plug hot
    last yr ran pump dry long story now this yr the plug gets very hot
    Jun 2013
    SpringHill FL
    415
    Re: pump electrical plug hot
    Sounds like a power draw issue rather than a pump issue. Is your pump pluged into an outlet or extension cord?
    Nathan
    15x30 gunite 18k gallons Hayward star clear plus 120sqft cart
    outlet
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    The easiest thing to check are the connections. Be sure the wires are good and tight on the back of the outlet and where the pigtail ends are connected inside the motor.
