Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: Hose adapters, where to find them...
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    I'll keep this short... shock, huh?
    Can threaded hose adapters that go on MP valves and pump skimmer baskets be found @ HD/Lowes/Ace type places? Or are they only available at pool stores?
    Also, do all filters and pumps use the same female id threads, or do they vary? Ie. V thread, buttress, npt and which is it?
    It's a Pentair Meteor MP and Dynamo pump.
    Do the threaded ball valves use the same thread type?
    Ready.... set... go!
    Thanks everyone!
    Tony.
    Thanks for reading... - Tony
    Da' Pool: Intex 15'x42" 3284gal AGP EasySet (Inflatable Ring) - (Summer 2014: 27' round EW /w 6.5' deep end @ 22,500gal)
    Pump & Cart Mod: 1000gph Cart. 5ft² - 2 nylons, 24/7 OP. Traps bugs/bits, lasts longer/cleans easier = Happier Pool Owner!!
    The Bible for a "Trouble Free Pool" life = PoolSchool, the BBB method a TF100 test kit(Recommend Kits Compared). - Cleaning a Sand Filter
    Water looks like GLASS, if yours doesn't...SLAM IT! Feels nice and never been happier!!! :D
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Hose adapters, where to find them...
    They should all be NPT.
    Essential Links:
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    Oh wow, really?
    You mean they didn't go and complicate everything like a government operation? lol
    That makes things easy.
    So what are they called, threaded hose adapters, or something else?
    thx.
    Tony.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    If you are talking about adapters for flexible hose, they are called barb fittings. Not sure we are on the same page with that one. Is that what you mean?
    Essential Links:
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    This is what I'm looking for.
    www.amazon.com/gp/aw/d/B002ZIZG0Y/ref=m ... -7&pi=SL75
    Think places that sell plumbing stuff would have these? I don't think Lowes does, haven't checked HD and our little mom and pop place.
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Seems hit or miss, some have them some don't, I usually found them in the irrigation section, not with the normal plumbing.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Those types are more specialty barbs...mostly for pools. Easier to order online, unless you want a pool store adventure. I've not seen them in any hardware store big or small, but they may carry them elsewhere. Sorry not to be of more help.
    Essential Links:
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    Naw, that's helpful enough. Thanks for the info, both of you. It has been helpful.
    Irrigation.... they have them that big?
    Sure, pool store adventures are fuuun!
    I'd buy it online, but I just haven't been able to take the time to do so.
    I'll buy it online if I have to.
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Pretty sure that's where I saw them at least once, buuuttt I could have old timers disease
    Dan D
    Jun 2013
    SpringHill FL
    415
    You can rig up what you need in the plumbing section. A threaded end then glue fitting to a reducer of the size you need. Get inventive lol
    Nathan
    15x30 gunite 18k gallons Hayward star clear plus 120sqft cart
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    Yeah, I thought about that, but it won't have the barbs on it so the hose will pop off from the pressure. Hose clamp or not.
    Or do they have barbed to slip joint pieces?
    If they do, I could do that.
    Thx,
    Tony.
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    Quote Originally Posted by msgtdan
    Heh, maybe! Never can tell whether it's the absent minded genius, or what. LOL
    What store did you buy it at?
    Jun 2013
    SpringHill FL
    415
    I recently purchased some at lowes in the plumbing section (they are grey)
    Nathan
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    Quote Originally Posted by FamilyGuy
    Which part did you purchase, the whole threaded adapter, or the slip joint reducer /w barbs you speak of?
    BTW, This "Slows" doesn't have any pool stuff, nor does "Home Despot". NOT POOL COUNTRY!!
    Oh, did I mention all the pool stores here are closed on Monday??? LOLs
    May 2013
    Fort Lauderdale, FL
    423
    Ordered mine from here. Keep scrolling down, they have straight with male or female threads.
    http://www.plumbingsupply.com/insertfittings.html
    45'x12' 17k gal, IG plaster, Pool Pilot Nano+ SWG, 1/2hp Whisperflo pump, PAC-FAB TA-60D sand filter, Raypak 266 heater
    Pool School + Test Kit + Pool Math = Trouble Free Pool
    Jun 2013
    SpringHill FL
    415
    The threaded barbed piece I will take a pic later ive gotta go to lowes in a little while
    Nathan
    Jun 2012
    western NY
    1,560
    At the Blue and orange stores, check the section that has sump pumps for these fittings. My orange has them there
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    Ok, thanks for the tips. I'll check it out, hopefully tomorrow. Spent all day yesterday in town, getting sand, among other things, then finishing setting up the pool once I got home.
    Today I did some more with the chems, then spent all evening cleaning up the used agp ladder I got. Diiiirty! Aaalgae, YUCK!
    Needless to say, I had little time today. I'm beat, gonna crash hard tonight! Hehe
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    I saw the barbed fittings at my Lowes in the pool chemicals area, outside in the garden area of the local store
    -- Guy --
  20. Back To Top    #20
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    Quote Originally Posted by techguy
    Unfortunately no chems or supplies sold here anymore, they stopped carrying them a few years ago.
    I checked @ HD, here's what I discovered.
    No barbed black poly fittings for pex over 1". Used to have them said an associate.
    They had a 1-1/2"-1-1/4" dual size threaded slip adapter in the sump pump section, just like you'd get at a pool place, but it didn't have barbs on it. Smooth only.... not good! Plus it had a check valve in it.
    So not what I needed, although I could have made the check valve work if it had the proper hose fitting.
    I even thought of using a dual male threaded coupler of the right size, this way I could get a threaded ball valve, remove the existing hose to thread adapter from the filter, attach it to one end of the ball valve, then attach the other end of the ball valve to the multiport using the threaded coupler. Nope, didn't have that either, fail there too!
    In fact, they didn't even have a threaded 1-1/2" ball valve, only slip. Uuuuggghh!
    EPIC FAIL!
    Need to check the pool stores, I know Lowes doesn't have the barbs, least not last year. But I'll check once more, as well as for the coupler alternative. There's also a plumbing supply place here that I need to check.
    I'll report back as soon as I can. Thanks for the tips.
