Thread: ECO-matic producing a LOT of chlorine
    Elgrecus's Avatar
    Feb 2013
    Los Angeles, CA
    57
    I started with a nasty green swamp and thanks to TFP I have absolutely crystal clear water. After shocking the pool, my FC level slowly dropped to almost zero in about three weeks. I added enough bleach to bring it to FC 3.5 ppm. I then inspected my ECO-matic ESC 36 and discovered a lot of scale. I realized it was not producing chlorine. After cleaning it in a diluted muriatic solution, it started working again just fine. I began running it at 100% for 5 hours per night (3:00 AM to 8:00 AM since electricity rates are so high here in Los Angeles). After a week, my FC level was up to 13.5 ppm. I reduced the run time to 4.5 hours and waited a week. I was up to 18.0 ppm. I then reduced it to 4 hours and now I am up to 18.5 ppm. Tonight I dropped the run time to 3 hours. My salt levels are high, but I am not sure how high. My Aquachek salt strips are giving me erratic results. Sometimes they say 4500 ppm (which is, believe it or not, ECO-matic's recommended minimum), other times they say 7000 ppm. I am going to buy the Taylor K-1766 in order to get more accurate readings, but in the meantime I am wondering why I am getting such excessive CH levels. I do have a small pool at 9000 gallons, but 4 hours a night of run time is not so great. Based on my pumps GPM, I recently read that 1.5 hours would turn the water over once per night (I have 15 feet of head). Am I approaching this the right way by decreasing the run time by half an hour a week? I did just drop it by an hour tonight, but if ECO-matic suggests an FC level of 1.0 to 3.0 ppm, I at way, way over that. Any thoughts? We're swimming in the pool just fine but my eyes are feeling a little bit of burning in the evenings. The kids don't feel a thing. Any thoughts are appreciated.
    Pool Size: 9,000 gallons
    Pool Type: In ground, plaster
    Filter: Pentair 4000 Series D.E. Filter
    Pump: 1 HP Pentair Whisperflo WFE-4
    Heater: Sta-Rite Max-E-Therm 200
    Salt System: ECO-matic ESC 36
    Pool Cover: CoverStar, motorized cover
    30,432
    Re: ECO-matic producing a LOT of chlorine
    What is your CYA level?
    Jun 2008
    Scottsdale, AZ
    37
    Why are you running at 100%? That's not good for cell life. In addition to reducing run time dial down the SWG.
    Gary
    18 x 38 28800 gals gunite inground;Purex Triton High Rate Sand Filter;1 HP 2 Speed Hayward Tristar Pump; Raypak Heater
    Aquabot Bravo; Goldline Aqua Logic Controller/SWG
    Elgrecus's Avatar
    Feb 2013
    Los Angeles, CA
    57
    My current CYA is 55 ppm. When we bought the house the CYA was at 20 ppm. I've been slowly bringing it up to ECO-matic's recommended 50-80 ppm.
    I haven't really done much research on what level I should be running the SWG. Should I reduce it to 90% for this week and see how it goes. Does that sound about right? Should I dial it back by 10% each week and reduce run time by 30 minutes per week until I hit the right FC level? Thanks for you responses.
    30,432
    With that CYA, you should be running SWG enough to maintain 3-5 ppm chlorine. Adjust it until it holds that level.
