Thread: How often to backwash Intex 2650?
    Just got this pump, LOVING it, but I'm curious how often I should plan on back washing the filter?
    I'm installing an inwall skimmer tomorrow if that helps with your answer at all.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    Re: How often to backwash Intex 2650?
    Instruction manual says when it reaches a certain pressure. Doesn't always work like that. Most of the experts here recommend when it reaches 20% over your clean pressure.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    +1 What Charlie said, so you may see a lot of flow loss before then...and then you will know.
    Essential Links:
    Jul 2009
    S. California
    I have it's smaller brother the 1600. I find that I really need to backwash as soon as the pressure gauge shows the slightest increase. Just a couple needle widths of change, and you can really feel the reduced flow in the return. That said, I run the pump for 8 hours per day and need to backwash about every two weeks.
    Your results will likely vary as we all have different load levels of extractable material in our pools. But this may give you a general idea.
    The 2650 is a really capable filter system, and a great value too. Congrats !
    18'x 52" Intex Ultra Frame AG pool
    7100 gallons
    1600 Intex sand filter
    TF-100 test kit
    BBB method for four seasons
    Former 18' Easy Set owner
    Jun 2013
    Newcastle, Oklahoma
    i think it depends on how dirty your pool is. my gauge on mine never really moves, i could probably backwash only once a month. i usually do it every two weeks irregardless of pressure reading. or if we get alot of rain, i backwash to let some water out and clean filter at same time.
    i never have to empty my prefilter either. my dynaskimmer catches everything.
    Partially buried Doughboy Desert Spring 16 x 32, sport pool, with 7 ft deep middle, 20,000 gallons, Hayward Powerflo Matrix 1.5 HP 2 speed pump, 250 lb sandfilter, 2 Doughboy skimmers and 2 returns. 2 cascade fountains.
    Taylor K-2006 kit. Zodiac Barracuda Ranger suction side cleaner.
    TFPC method and is crystal clear every day thanks to TFP!!!
