Thread: Raypak RP 2100 digital
    2003. The unit fired up, but after a lengthy time, perhaps 20 seconds or more, and there was that loud whoop sound of a lot of gas igniting at once. It was heating, I thought so I left it and upon my return about an hour later, it wasn't burning. It displayed the diagnostic code IGN. The top was not hot so after it fired up. it must have shut down quickly. What does the IGN code indicate and how can I address it? Any help is greatly appreciated.
    Jun 2012
    western NY
    1,560
    Re: Raypak RP 2100 digital
    I believe on those the "IGN" code is an ignition fault lockout. To clear it you have to turn the unit off, then back on. However, with the symptom you described, I would pull the burners and make sure they are clean. Sounds like the burner nearest the pilot light/igniter is clogged and it is taking some time for the gas to accumulate before igniting.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    ps0303's Avatar
    Jul 2011
    FL
    3,701
    IGN Indicates loss of flame signal at the pilot after main gas valve power has been applied. The board will reset itself and make three attempts on same CFH(Call For Heat). If the unit fails to hold flame after three attempts, it will go into a hard lockout(ILO). Interrupt the power supply to clear the lock out.
    I am guessing your running on propane?
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Thank you. I pulled out the burner tray, lifted up the first burner, unscrewed the threaded head that attaches to the individual gas lead and made an adjustment to the head to align it with those of the others burners. Turned the apparatus upside down to shake loose any debris and re-assembled the burner tray. It worked. And yes, it is on propane.
    ps0303's Avatar
    Jul 2011
    FL
    3,701
    When you put it back together, did you use pipe dope?
    Paul
