Thread: system backwashes immediately thru skimmer when pump stops.
    For the last month, my system has "burped" back thru the return line to the skimmer basket when the system turns the pump off, enough so that it flips the skimmer basket upside-down every time... there are no air leaks in the system that I have been able to find. Just rebuilt all connections in the chemical feeder system, all good there. Any suggestions?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: system backwashes immediately thru skimmer when pump sto
    Welcome to TFP!
    It's almost certainly air in the filter. Any issues with the skimmer weir hanging? Is the pump basket 100% full of water with no air in it?
    22,542
    Once the pump is running, bleed all the air out of the filter and see if more accumulates. If it does you have a suction side air leak.
