Thread: Auto Pilot out of control
    Jun 2007
    Boise Idaho
    58
    Need help with my one year old autopilot SC-60. I have been testing my chlorine levels over the last month with readings in the 5.5 level for both TC and FC, however these number have jumped off the charts recently. I do not believe it had anything to do with adding borates to the pool.
    I took a sample to the pool store today to find my reading have gone to 8.5 TC and FC with CC at 0. I also used the dilution method with the taylor kit to get the same high readings.
    I looked over my cell setup and found that my pool volume was set to 29800, however my pool volume is more like 25500. Could this be the cause of the increase in TC/FC?
    Here are my current readings..
    FC 8.5
    TC 8.5
    CC 0
    PH 6.9 (however my taylor kit reads 7.4, so I wonder if it was because it road in the car to work and then to pool store)
    T/A 101
    CYA 35
    Borates 44 (yes I pulled off the muriatic acid and borax, everyone thought I was crazy....)
    TH 103
    Salt 2200 (HOWEVER, the auto pilot is reading 2800???)
    Any help would be much appreciated.
    Other settings are: cell power = 1, purify level = 40%
    I have never calibrated the cell as I do not have a salt test kit.
    What's the best corrective action? Is the pool safe for kids?
    __________________________________________
    18x36 inground, sand filter, sta-rite sr400 ng heater
    Re: Auto Pilot out of control
    Just lower the percentage.
    Jun 2007
    Boise Idaho
    58
    Too easy.....Thanks Jason...I set it to 0% for a few days and will watch for the level to drop. Is 8.5 too high for the kids to jump in today?
    Any ideas of why the pool store versus auto pilot salt reading?
    Also the PH at pool store 6.9 versus taylor kit of 7.4? That's a pretty big delta?
    Can you recommend a salt test kit to calibrate my autopilot?
    whoozer's Avatar
    Apr 2008
    Acton Maine
    633
    Duraleigh at tfkits here has salt test strips. His link is in the vendor section of the home page.
    14x33 fiberglass freeform
    Variable speed Pentair intelliflo superpump
    420 Clean and Clear Plus cartridge filter.
    pool-school/pool_calculator , http://www.tftestkits.net/
    Swimming is fine. Don't trust pool store test results. AquaChec salt test strips are good.
    Ft Lauderdale, Florida
    1,455
    You can go into the MAINTENANCE MENU to calibrate the salt display to match your salt rest results.
    While you're adjusting the system, go to the INSTALLER MENU and adjust the POOL VOLUME.
    I would recommend increasing your CYA level to between 60 and 80 ppm.
    Lowering the %setting, as Jason mentioned, will also help.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
