Thread: Pump not priming
    Pump not priming
    Hello..I'm a new pool owner of a 24' octagon inground pool with sand filter. Pool was working with no problems until I back washed this morning and now I have lost prime to the pump and cannot figure out how to get the system working again. I appreciate any ideas...thanks. Jerry
    30,402
    Re: Pump not priming
    Tell us what happens when you power up the pump.
    I fill the basket up on the pump. I cleaned out both filter basket and skimmer basket. Pump comes on, impeller spins, empties basket but no water coming from lines back into pump filter
    30,402
    It sounds like You have a suction side air leak. Somewhere between the pump and the skimmer(s), air is being sucked into the system. Find that leak and your priming issues will be solved.
    That's the problem...either the pipes are under ground or underneath a deck that I will need to take out before I can even trace the line
    Jun 2013
    SpringHill FL
    415
    Did you check to see if your pump basket lid was sealed tight. Open it up lubricate the o ring while checking for kinks or defects
    Nathan
    15x30 gunite 18k gallons Hayward star clear plus 120sqft cart
